Spec Boxsters For info sharing on this exciting new class
Spec Boxster for sale
Old 08-22-2017, 03:40 PM
Greg Holmberg
Greg Holmberg's Avatar
Default Spec Boxster for sale
Listing on Rennlist
Old 08-24-2017, 03:15 PM
johneecatt
johneecatt's Avatar
Nice build - beautiful ! GLWS!
Old 09-23-2017, 05:33 PM
Greg Holmberg
Make me an offer--tell me what you think it's worth.
Old 10-24-2017, 04:36 PM
Greg Holmberg
I haven't received much interest in the car. Is it the rear fender damage? Do I have to fix the fender before anyone will buy the car?
Old 10-25-2017, 06:00 PM
Greg Holmberg
New: lower price, $28,000.
Listing on Rennlist
Old 01-03-2018, 08:35 PM
Greg Holmberg
Bump for the new year. Someone out there must need a professionally-built spec boxster for the coming year.
Old 01-05-2018, 01:13 AM
txhokie4life
txhokie4life's Avatar
Not knowing the car -- what would you think if you saw sheet metal damage on a race car that was unfixed?
For the price you are asking -- I would expect the car to be damage free. I think the lack of interest is suggesting the same.
Mike
Old 01-05-2018, 08:22 AM
Gary R.
Gary R.'s Avatar
Not sure what the market is out there Greg, but my car had everything you list plus GT3 control arms all around, Full AIM MXL2 data system with throttle/brake sensors, AIM SmartyCam HD, Coolsuit, all Tarret drop links and bars, two sets of wheels, factory Hardtop (no net needed), no dents, and more.. and it sold for a little less than what you are asking (on the East coast).
Old 01-08-2018, 01:56 PM
mmuller
mmuller's Avatar
It also doesnt have race history/results associated with it. This often times can add value to the car if its a known winner. Your car is currently an 'unknown quantity' and as such gets valued strictly on the sum of its parts, not what its potential is.
Old 11-23-2018, 03:36 PM
Greg Holmberg
Still for sale. Make me a reasonable offer.
Built by The Speed Gallery (Dan Aspesi) in North Hollywood, CA. Pro-built engine (check the dyno chart in the ad), street-legal and licensed in California. Car is located in Lafayette, CA 94549 (San Francisco bay area)
Rennlist ad
Photos
Greg Holmberg
Please don't use private messaging, I don't check it.
mailto:holmberg2066@comcast.net
Voice or text: +1 925 334 1383
Old 02-04-2019, 04:21 PM
Greg Holmberg
Still for sale. I now have these documents to help you decide:
1. build spec sheet signed by builder Dan Aspeci at The Speed Gallery.
2. receipts for additional work done.
3. car fax.
4. a pre-purchase inspection from BR Racing in Los Gatos (sponsor of the local PCA racers, has worked on many spec boxsters).
5. two estimates for the body work. One to replace the fender, and one to pull it out and bondo it.
6. California certificate of title with VIN.
7. odometer reading: 97,284.
8. the dyno sheet from MCE Racing (does all the dynos for NASA).
See all these documents and photos of the car here.
Greg
Old 02-04-2019, 04:34 PM
Greg Holmberg
Default Pre-purchase inspection
Here's a summary of the pre-purchase inspection from BR Racing, in case you find it hard to read in the photograph.
  1. One wheel bearing should probably be replaced.
  2. Car has stock brake rotors not the slotted or drilled ones.
  3. Front brake pads should be replaced.
  4. Rear brake pads are fine (60% left).
  5. Car does not have the extra radiator in the center. (Not really necessary unless you live in Texas, in my opinion).
  6. The end-links on the rear sway bar are stock (not adjustable). You probably want to get the adjustable ones from Tarrett.
  7. Rear sway bar is not connected (I did so for a wet day I ran).
  8. Missing one of the plastic underbody panels. (I think these are about $100).
  9. The rear lower control arms are stock. You'll probably want to replace these, you get about 1/2 a degree more camber. I don't know the cost.
  10. There's a way to connect the rear lower control arms to lengthen the wheelbase 1/4" or so. It's a minor improvement, but you might as well do it since it doesn't require any new parts.
  11. Driver's seat was manufactured 12/2012. It will need to be replaced or have a back support created for it.
  12. Seat belts expire in 2020.
  13. Fire bottle was not in the car (I left it at home).
  14. The fire system on switch is next to the driver's leg and could get flipped off accidentally. Should relocate it.
  15. Battery is stock (heavy, 38 lbs).
  16. Wiring in the car is stock. You can get lighter-weight ones with fewer wires.
  17. There's a spare tire in the front trunk.
  18. The cable for the battery cut-off switch--they don't like the way it's routed. They think it would be too hard to pull. Personally, I had no problem pulling it.
  19. Body damage.
  20. Car has a passenger seat installed.
  21. Stock shifter on risers.
  22. Parking brake is still installed.
  23. Has stock hood releases front and rear. You might like to have hood pins installed.
  24. Has wheel studs.
  25. Has a quick release on the steering wheel.
  26. Windshield wipers are still installed.
  27. Roof not on car (I left it at home).
  28. No roof net (I use arm restraints).
  29. Has catalytic converters still installed. Straight pipes would get you about 5 more HP.
  30. Needs a rear tow hook.
Old 10-06-2019, 05:28 PM
Greg Holmberg
Default New price $20,000
Make me an offer. Car is in the San Francisco Bay Area. Street-legal and licensed in CA. Above-average engine, 20.5 lb wheels.
Listing on Rennlist
Old 10-16-2019, 05:28 PM
Greg Holmberg
Car is sold.
Staying in the San Francisco Bay Area.
Going to an SCCA racer, who will race it in class T3. This class uses the Hoosier R7 tire, so the Spec Boxster is a few seconds/lap faster than with the Toyo RR tires. Also, SCCA minimum weight is 2600 lbs with driver, 50 less than with the PCA. So it should be competitive in T3 against the BMW SpecE46 and the V6 Mustang.
Quick Reply: Spec Boxster for sale
