WTB: Front devek swaybar.
Not sure he still has it, but ChuckZ had one.
I'm pretty sure that's what on this GT I bought.
As I remember Devek did two bar sizes, the slighly narrower one intended for earlier models as I remember.
Mine is the heavier one and is painted blue as in that "now sold" sale on e-bay.
Have you treated yourself to some wider front wheels to justify its use along with all the other goodies you have just acquired?
Rgds
Fred
Rgds
Fred
Administrator - "Tyson"
EDIT - here we go:
https://rennlist.com/forums/928-foru...l#post10739686
The Devek sway bar is available in two stiffness ranges. Standard and Super Duty. The Standard is best suited for the driver of the lighter weight 78-84 928s who seeks additional control for weekend driving events, autocross and hard street driving. For the heavier 85 and later 928s, as well as road course race- prepped cars, the Super Duty is the right choice. The standard bar is adjustable from 21% - 140% stiffer than the stock bar, and the Super Duty bar is adjustable from 67% - 240% stiffer than stock. All Devek sway bars come with Teflon bushed Heim joints for a quitter ride at no additional cost.
Both bars cost $498 each
Above is from the Devek catalog - volume 3 circa early 2000.
Clearly there had to be a reason they felt that two models were needed.Whilst on the subject when they say they are 67% to 240% stiffer I have understood that to mean 67% stiffer than stock at the softest end of the range rather than it starts at 67% of stock stiffness and it adjustable up to 240% of stock stiffness- any different interpertations on that?
Rgds
Frecd
Rgds
Fred
Rgds
Fred
Front adjustable will give me some latitude to tune over/under steer tendencies at least.
You looking for the blue, black, doesn't matter?
Garrity has this one on eBay. Guessing it's one of the 928 Specialist units?
http://www.ebay.com/itm/USED-PERFORM...pYqNYJ&vxp=mtr
However once you run serious rubber up front and start to have oversteer, having non stock rear links with the Devek bar ceases to make sense. I am in that position and the only reason I retain the Louie links is because I lost my stock ones in a house move - durrgh! The Devek bar has such an operating range it is not a problem. With my current setup- now running 255's up front and 285's on the rear, the car feels very happy with the bar set midway.
Either way the Devek bar is a great addition for those with serious handling intent and I am sure you will love it assuming you stumped up for that one on Ebay.
Rgds
Fred
