Parts Search
Keyword:
Category:
Price (no $ sign please):
Private or Vendor Listing:
Location (Region):
Item Condition:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Color:
Private or Dealer Listing:
Location (Region):
Transmission Type:
JRZ RS Pro DA Coilovers
Old 03-10-2017, 06:18 PM
bmwtye
bmwtye's Avatar
Default JRZ RS Pro DA Coilovers
Price (no $ sign please): $3200
Location (Region): NorCal
Item Condition: Used
I have a lightly used set of JRZ RS Pro 2-way adjustable dampers with Eibach springs. 600# Front and 800# rear along with helper springs. Also has solid aluminum top mounts and quick disconnects.
I had these on my 2007 GT3, but am going in a different direction so put the stock shocks back on for now. These have about 2000 miles on them.
$3200
Located in SF Bay Area for local pickup or can ship them (buyer pays shipping)
About the RS Pro Line
Taking club sport performance to the next level, the RS Pro has a remote canister with a digressive blow off system. Digressive blow off allows for a stiff compression valving while maintaining smooth response. The result is a damper that provides ultra solid platform with smooth bump compliance. JRZ standard 22mm piston rods maximize flow to the blow off valve response to great chassis control without using a high spring rate. To customize track to track setups and tailor the chassis to the JRZ RS Pro has an extra large adjustment range. Each adjustment is designed to be an even step giving you predictability when making changes.
Features:
• 22mm rod strut, 16mm rod damper
• 12 clicks of compression, 24 clicks of rebound
• Adjustable gas pressure, monotube
• Piston designed for high performance
• Large adjustment range
• Fixed hoses for easy mounting, available quick disconnect fittings
• Remote reservoir canister
bmwtye is offline
Old 03-10-2017, 09:14 PM
powdrhound
powdrhound's Avatar
Received 1,786 Likes on 1,042 Posts
Fantastic suspension, great seller, great deal..
powdrhound is offline
Old 03-15-2017, 05:58 PM
bmwtye
bmwtye's Avatar
bmwtye is offline
Old 03-15-2017, 11:38 PM
mickfluff
mickfluff's Avatar
Amazing suspension set up here.
Surprised hasn't gone yet.
GLWS
mickfluff is offline
Old 03-26-2017, 07:27 AM
RajuPatel
RajuPatel's Avatar
would this fir a 2007 997.1 turbo TT?
RajuPatel is offline
Old 03-26-2017, 04:37 PM
21212's Avatar
Is this the basic 1131 series or something else?
21212 is offline
Old 03-26-2017, 05:08 PM
bmwtye
bmwtye's Avatar
My understanding is yes but I will confirm.
bmwtye is offline
Old 03-26-2017, 05:12 PM
bmwtye
bmwtye's Avatar
The 11/12/14 series is the newest JRZ.
These are from the series before those. I would have to ask JRZ what the difference is between the 1131 and these
bmwtye is offline
Old 03-26-2017, 05:47 PM
powdrhound
powdrhound's Avatar
You will need front JRZ shock body adapter sleeves and JRZ awd front upper mounts. About $700 in parts. I have those. Other than that, all the parts are identical.
Old 03-26-2017, 06:16 PM
bmwtye
bmwtye's Avatar
Thank you for helping out. What I found out is exactly what you said.
For 997 Turbo required front strut sleeves, angled front top plates, and front sway bar drop links that mount up to the wheel carrier instead of the strut itself. The OEM Turbo/c4 front sway bar drop links mount to the strut which causes unwanted strut body flex for track use.
Also, these are direct fit for 997 GT2.
bmwtye is offline
Old 04-04-2017, 07:11 PM
bmwtye
bmwtye's Avatar
still for sale
bmwtye is offline
Old 04-07-2017, 02:09 PM
Spiffyjiff
Spiffyjiff's Avatar
any track time in the 2000mi?
Spiffyjiff is offline
Old 04-07-2017, 08:35 PM
bmwtye
bmwtye's Avatar
1 track day very early on in that mileage
bmwtye is offline
Old 04-19-2017, 01:28 PM
bmwtye
bmwtye's Avatar
bmwtye is offline
Old 04-27-2017, 11:05 PM
GT3_PILOT
GT3_PILOT's Avatar
Will these be direct fit to a base 997.2?
GT3_PILOT is offline
Quick Reply: JRZ RS Pro DA Coilovers
