964 C2 3.8 Build Thread
1990 C2 5 speed
Silver / Linen
130k mile California Car - no rust.
Tim Olsen build ... Tim is one of the best in the business. He will not accept anything but the best for his work.
Paint:
Windows out, bare metal full repaint to different color.
Fashion Gray - H61 (991 PTS color code)
- Sunroof Delete - Fenn Lane.
- Getty Ducktail.
- Stock tail.
- 3.8 RS tail ... no one would buy the one I have so it's getting painted with everything else.
Engine: Eurosport Racing - Joliet (George Weathered)
3.8 liter, split case rebuild with new bearings.
- New Mahle Jugs and Pistons 3.8.
- Rebuilt heads.
- Custom ground cams.
- Steve Wong Chip.
- LWFW.
- Carbon Fiber Heat delete for weight - Rennline.
- A/C Retain.
Exhaust:
Fabspeed RSR with heat, catless dual outlet. Jet hot coated.
Suspension:
- JRZ RS2S.
- Adjustable camber plates.
- Brembo 355 front 328 rear kit - Yellow
- Rennline motor mounts.
- Golden Rod shifter kit.
- Rennline Trans mount.
- Elephant Racing - Sport hardness bushings throughout.
- Adjustable Drop Links.
- RS Front and rear sway bars.
- Rennline 3 point strut tower brace.
- Rennline steering rack brace.
- New wheel bearings and cv joints.
- New LSD.
- New inner and outer tie rods.
- RUF aux oil cooler mounted in onto air con condenser.
Interior - Classic 9 in Detroit (Bob)
- Momo Alcantara Wheel ... style not set.
- Quick release for wheel.
- Recaro CS Seats.
- RS Carpet Set.
- RS Door Cards with Speed yellow pulls.
- Yellow Standard Seat Belts
- Yellow Racing Belts
- Yellow Tach
- Heigo Bolt in rear cage - cerakoted in black graphite.
- Center console in Alcantara.
- Gray deviated stitching, dash, center console and in other limited areas.
- Black Shifter with yellow shift pattern
- Lower dash delete (maybe skip but weight loss is tempting)
- Back Seats refinished in Alcantara to match fronts for re-install over RS carpet set when 4 passenger configuration is desired.
Stereo - Custom Installations (Mike Neckel)
- Alpine lightweight radio ... no cd.
- 6 x 9's focals custom mounted under RS carpet set thus invisable.
- Rear foot well subs - quick release for easy removal for DE or rear seat configuration.
- JL amp custom installed in front spare wheel.
BBS E88s with centers finished in silver for now.
- 18 in Sport Cup 2s, heat treated with full treads
LED Headlights Flat6Illuminations.
- Tinted H4 flutes lenses, Yellow, Clear and Flutes lens options to mix it up ... easy to swap.
- Trim rings in body color and cerakote.
Silver / Linen
Paint:
- Getty Ducktail.
- Stock tail.
- Rebuilt heads.
- Steve Wong Chip.
- LWFW.
- A/C Retain.
Exhaust:
Suspension:
- JRZ RS2S.
- New LSD.
- Recaro CS Seats.
- RS Carpet Set.
- Yellow Tach
Should be a neat build ... will post pics. Motor is apart, heads being redone, cams are being ground. Car is apart for paint ... I'm having a ducktail, standard tail and a 3.8 RS tail being painted at the same time so I can interchange.
swaini (11-30-2020)
Love how you are getting all the different tail prepared now. I'd so love to switch tails depending on purpose or mood.
Bore-in I hope?
Should be a fun build
Sounds like an expensive project, but the result should be very worthy.
Singer MN car looks to be metallic slate grey with some pearl added.
Best of luck & looking forward to checking in on progress.
with all that do the chassis in full, it won't be cheap, see my build thread in signature.
Holy cow! You've done an amazing job on your ride. Luckily I've got Tim Olsen from Olsen Motorsports doing up the suspension and braking on mine and he is a master and a great guy to boot!
I'll ask him to check out your thread ... I think he probably has already.
Thanks for the input and I will be reaching out to you in the coming weeks / months if you don't mind. Actually interested in your wheel studs but link doesn't work anymore. Is that company still in business?
Thx
