Durametric Tool Cannot Access Stability Management Module
Old 10-30-2016, 08:05 PM
Scott McKinney
6th Gear
Scott McKinney's Avatar
Question Durametric Tool Cannot Access Stability Management Module
I have a 2006 Porsche Cayenne S. I cannot access the Stability Management module with my Durametric tool. I have tried a replacement cable from them, but it did not help. I have logged the situation, but Durametric does not have a solution for me. Everything works fine in the vehicle including ABS, traction control, etc. Any help would be greatly appreciated, thanks! Here is a video of the issue:
Old 10-31-2016, 04:07 AM
Sniffer
Sniffer's Avatar
My guess - communication part of the module is faulty
Only way to know for sure it to swap it and see if that clears the issue but before I do that I`d check all the wiring to it as a first step
Old 10-31-2016, 01:22 PM
Scott McKinney
6th Gear
Hmm, Is this even possible since all the actual functions of the system work in the vehicle without flaw?
Old 10-31-2016, 01:38 PM
Sniffer
Sniffer's Avatar
In my opinion - yes
Think about it like this, if the wifi on your laptop (i.e. the communication part) crapped out most likely the rest of the laptop would still work just fine so it is possible for some aspects to fail in isolation and not affect others
Old 02-24-2018, 01:04 PM
8202632's Avatar
i have the same issue. Did you get any resolution on this?
Old 02-25-2018, 05:39 PM
Martynban
Martynban's Avatar
I still have the issue with my durametric cable too. Their support is awful too.... 3 months ago they were ‘working’ on it.
Quick Reply: Durametric Tool Cannot Access Stability Management Module
