JRZ RS Pro Coilovers With Extra Springs
Price (no $ sign please): $4500
Location (Region): SouthEast
Item Condition: Used
JRZ RS pro piggyback dampers with 2 sets springs and tenders. Fits 2000-2005 996 turbo and 2002-2005 C4. First spring set: 686lb/in for front and 799 rear. 2nd set: 799 lb./in front and 914 rear. 3400 miles.
I also have Tarrett adjustable drop links available for $325.00
Features:
22 mm rod strut, 16 mm rod damper
• 12 clicks of compression
• 24 clicks of rebound
• Adjustable gas pressure, mono tube
• Piston designed for high performance
• Large adjustment range
• Fixed hoses for easy mounting
• Remote reservoir piggyback canister
• * *Better chassis control for higher rate springs/power/ratio
•*** Street ride, racing performance
•*** Easy to change configurations
* Recommended applications
* •*** Highly modified Street/DE
•*** Experienced club racing
•*** Entry level professional racing *
Al@alnorton.com
770-401-0102
