FS: BNIB MoTeC C185 Display Logger
Category: Audio/Video/Electronics
Price (no $ sign please): $4500
Part fits (select ONLY those which apply): Race Car
Location (Region): NorthEast
Item Condition: Brand New
The vivid 125mm screen (approx. 5") is high resolution, ultra bright and anti-reflective for easy reading in direct sunlight. Numerous selectable layouts are provided with superb graphics that cater for day and night viewing. Within these layouts users can configure the channels and labels to suit their application.
An array of ten full color LEDs is integrated into the unit for use as shift lights, warning lights or other driver alerts. The color, function and intensity of each LED is programmable, allowing users to develop their own unique strategies and sequences.
Display
- Screen: Color TFT LCD, anti-reflective
- Resolution: 800 x 480, anti-aliased graphics
- Selectable fixed layouts with channel and label configurability
- 48 user-defined, scrollable message lines with programmable overrides
- 3 programmable 'pages', for example Practice, Warm-Up, Race
Logging
- 250 MB logging memory (500 MB optional)
- Logging rates up to 1000 samples per second
- Fast Ethernet download
- Includes i2 Standard data analysis software (i2 Pro available as an upgrade)
Communications
- 4 x configurable CAN buses with individually programmable CAN bus speeds
- One can be used as RS232 Receive
- Two CAN buses support VIM/SVIM Expanders
- 2 x dedicated RS232 ports
Physical
- Dimensions 134.5 x 103.9 x 20.2 mm excluding connector
- Weight 410 g
- 1 x 79 pin Autosport connector
Inputs
- 10 x analogue voltage inputs (20 with I/O Upgrade)
- 4 x analogue temperature inputs (8 with I/O upgrade)
- 4 x digital inputs
- 2 x switch inputs
- 4 x speed inputs
Outputs
- 6 x low side outputs
- PWM or switched operation
Internal Sensors
- 3-axis G sensor
- Dash temperature sensor
- Sensor supply voltage
- Battery voltage
Expanders
- Compatible with MoTeC E888 and E816 Expanders, providing full functionality.
- Compatible with VIM/SVIM Expanders
This is a brand new, new used MoTeC C185 dash, has not even been connected to a mating connector or mounted. I was planning to use this on another project, however, plans have changed and I have no use for a second C185. It does not have any unlocks, although if you are interested in having certain functions unlocked you can let me know and we can arrange a deal. If you have any questions or would like to make a best offer, feel free to contact me either here via private message or shoot me an email to info@MaciejRogozinski.com.
