FS: 996 GT3 MCS 2-way Custom Suspension!
The Rebel
Price (no $ sign please): $5895
Location (Region): SouthEast
Item Condition: Used
They were used for 16 track-days only...sold the car but didn't include it in the sale. These are virtually brand new!
It retails (with all the options on it) for over $7000!
My price is $5895 OBO shipped with CONUS.
The MCS 2-Way damper is far from basic. This damper set features a full 14 clicks of compression adjustment and 18 clicks of rebound adjustment over a wide range, specific to each vehicle’s specific requirements. Remote reservoirs give superior fluid temperature control and are available (or standard depending on application) with quick-release hydraulic lines for easy installation.
This damper set is beyond the more common coil-over systems on the market. MCS 2-Ways are dependable, repeatable, and easy to work with. Valving covers a wide range of spring rates and eliminates the need to constantly revalve every time you want to increase or decrease your spring rate. Reservoir pressure can be adjusted between 100 – 275 PSI to help support the platform in fast cornering or generate more weight transfer / traction at low velocity.
Dampers are more than just number of adjustments and just click count – the shape of the resulting curves is specifically engineered to give your car the most grip through the range of surface conditions and dynamic inputs your vehicle experiences.
Pictures:
![](http://i58.tinypic.com/339hq4i.jpg)
![](http://i62.tinypic.com/30ud1d4.jpg)
![](http://i57.tinypic.com/2lwkgpk.jpg)
![](http://i62.tinypic.com/eled1w.jpg)
![](http://i57.tinypic.com/28l7410.jpg)
Pictures of when they were installed:
![](http://i62.tinypic.com/2dqqz50.jpg)
![](http://i61.tinypic.com/w9yzhz.jpg)
