Zeitronix Zt-2 and ZR-2 Combo with ZAVT-1
Category: Audio/Video/Electronics
Price (no $ sign please): $350
Part fits (select ONLY those which apply): 911, 912, 914, 924/931/944/951/968, 928, 964, 986, 987, 993, 996, 997, Cayman, Race Car, Other Marques
Location (Region): West
Item Condition: Used
In this kit the Zt-2 Model 2010 Wideband is bundled with the amazing ZR-2 Multi-Gauge. The ZR-2 Multi-Gauge displays Air/Fuel ratio or Lambda values, Boost/Vacuum, Exhaust Gas Temperature, and data from the configurable 'User2' input. The ZR-2 Multi-Gauge has a peak and hold feature. High contrast LEDs are visible even in a direct sunlight.
Includes the Zt-2 Model 2010 Wideband Air/Fuel Ratio Meter, Wideband Oxygen Sensor, 10ft* Sensor Harness, Signal Harness, PC Serial Cable, Datalogging Software, Installation Instructions and 2-Pin EGT Connector to retrofit your EGT probe. Data splitter included for simultaneous display and datalogging use. Made in the USA.
Also includes ZAVT-1
The compact ZAVT-1 module adds fail-safe operation to Zeitronix Zt-2 Wideband Systems. The ZAVT-1 contains a loud 95 dB rated buzzer and bright red LED for notifying the driver of a problem. Fail-safe operation is achieved using the optional relay to trigger a boost solenoid, methanol water injection or ignition cutoff.
The Zt-2 Wideband controller will monitor user set levels triggering the ZAVT-1 Warning/Trigger box and optional relay if one or a combination of values exceeds limits. Trigger a failsafe condition on any Zt-2 input including AFR, Boost, RPM, TPS, EGT, Oil/Fuel Pressure, Air/Water temperatures and more. Create a failsafe gauge/display with the Zt-2 controller watching both displayed values and any other connected sensors or inputs. This simple failsafe safeguard is a great way to protect your engine, hardware and time investment.
See the Zeitronix website for more detailed information. (zeitronix.com)
