996 Forum 1999-2005
View Poll Results: Has YOUR car suffered an IMS failure
Yes, the IMS failed
8.67%
No issues with IMS
91.33%
Voters: 1591. You may not vote on this poll
IMS bearing failure for your 996, Y or N? tell us (yr, 996 Mk1 or MK2 failure mode)
Old 02-03-2013, 10:41 PM
Marc Gelefsky
Super Moderator
Marc Gelefsky's Avatar
Default IMS bearing failure for your 996, Y or N? tell us (yr, 996 Mk1 or MK2 failure mode)
As requested I have posted this poll.
Many have been asking to understand how many of the 996 cars have had IMSB (intermediate shaft bearing) failures. Although the people on this board are not necessarily a random sampling of 996 owners many have asked to see a poll to get a better sense of it.
  • Please vote only once for each 996 you own (yes or no).. you can post multiple times but only vote once
  • Please include details of your car and engine if it failed via IMS and when.
  • Please let us know if there were any mitigating factors (low oil, overheat, etc) that might have led to the failure
  • Please post only about IMS failures, this is not about RMS failures
  • Please post only for your car, no heresay or posting for a friend who doesn't frequent the board
  • Please post what was done to rectify the failure if your car failed (CPO engine, engine out of pocket, used engine, sold, insurance fire, pushed it into a river etc)
Please ONLY POST DATA HERE. Not discussion.
Hopefully this will help owners and soon-to-be owners get a sense of how frequently this occurs.
*Thanks*
Popular Reply
04-06-2023, 12:58 AM
996_aero
996_aero's Avatar
Default ‘99 C4 Dual Row - FAILED @ 112k
I bought a ‘99 C4 almost exactly a year ago with 109k miles. I had always planned on doing the IMS bearing with the next clutch replacement. But clutch has plenty of life so I assumed this was a ways out.
Left town for a few months and returned home to two big puddles under the car. One right beneath the bellhousing. See photo — the smaller of the two large leaks was the one under the RMS, the larger was actually a cracked coolant expansion tank.
Decided it was a big enough leak to investigate even though primary suspect was RMS.
Dropped the tranny, and decided to replace the IMS bearing proactively with the LN retrofit kit.
Good thing too… IMS bearing was completely shot. My car is a very early MY99, with a dual row bearing. It was MISSING ball bearings, and there was a ton of play in the bearing itself. Honestly a miracle that the failed bearing hadn’t led to anything catastrophic. It was truly a ticking time bomb.
I’ve done Blackstone oil analysis with each oil change since my ownership and never saw any sign that the bearing was failed, save the leak in the garage.
Bullet dodged!
Weepy RMS leaked onto the IMS bearing, at this point not clear where the source of the leak was.
Failed dual row IMS bearing. Engine survived.
New LN engineering bearing.
Old 02-04-2013, 12:29 AM
perryinva
perryinva's Avatar
49k miles currently. Not yet.
Old 02-04-2013, 12:46 AM
street rod
street rod's Avatar
2001 C4 - 62k and no issues. I proactively installed an LN dual row bearing and now have 68k and still running good.
Old 02-04-2013, 12:49 AM
Cefalu
Cefalu's Avatar
1999, No failure of Dual row IMSB, but preemptively replaced with LN ceramic at 60,000 miles.
Original IMSB still sealed and showed no signs of wear at 60,000 miles.
Original motor, not a replacement.
Old 02-04-2013, 12:50 AM
Steve's MLC
Steve's MLC's Avatar
No issues. Replaced for peace of mind with LN at around 58k. IMS is on my desk at work and I tell people it's a $15k part.
johnslageljr (11-23-2019)
Old 02-04-2013, 08:09 AM
balefire
balefire's Avatar
No issues on my 996 mk2 40th anniversary.
As many veterans of this forum know, these polls suffer from selection bias, incomplete sample size, unknown denominator, fake posts, etc.
But some data is better than no data.
Here is my contribution to the data with a known denominator due to the 40th anniversary fixed production. In our series, it is at least 0.5%.
https://rennlist.com/forums/996-foru...ml#post7631524
Here is the 997 forum poll data which is around 5%
https://rennlist.com/forums/997-foru...lure-mode.html
If fake posts present a problem in the future, we could always do just a poll with Rennlist members...
The following 5 users liked this post by balefire:
blightyusa (02-11-2024), cucumber (04-02-2020), janikphoto (02-29-2020), Nate.Evans (01-27-2022), Pepperdog01 (01-23-2020)
Old 02-04-2013, 08:40 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
'99 original dual row with 200 000 miles. Replaced it with a hybrid dual row (From Boca Bearings). Old bearing still looked and felt good.
Old 02-04-2013, 08:44 AM
aviography
aviography's Avatar
Marc,
IMS or IMSB? Perhaps the title should be updated even though most know it is IMSB.
Old 02-04-2013, 08:48 AM
Dharn55
Dharn55's Avatar
70,000 mile on a dual row bearing and no problems. At 50,000 mile when I had the engine dropped to fix a cracked head/intermix I did replace the IMS flange with the updated flange and removed the seal on the bearing. Next time the engine is out or the trans is dropped I do plan on installing the LNE bearing.
Old 02-04-2013, 09:08 AM
csubtil
csubtil's Avatar
70.000 miles on OEM bearing. 2004 996 C4S Cabrio.
Had the the IMS flange replaced (+RMS) 1.000 miles/3 months ago at local OPC. At the time I didn't have enough knowledge to ask the OPC how the IMSB was or if they have replaced the IMS flange because they "were in there"... Just knew I had a leak and asked them to solve it...
They just suggested replacing the clutch at the same time, which I did.
I estimate doing 5.000 miles at max this year, so maybe next service I will ask the OPC to replace it for the LNE or the INSARO IMSB. On the other hand, I have read at 911uk forums that Hartech (major UK M96 rebuild specialist) doesn't like to replace IMSB on currently "good" running 996's...
This IMSB thing is a bit confusing to a newbie 996 owner like me...
Old 02-04-2013, 09:20 AM
mlambert890
mlambert890's Avatar
2002 27k mi and no issues
My old 1999 I owned for 3 years and 50k mi and no issues on that one either
Old 02-04-2013, 09:32 AM
Sneaky Pete
Sneaky Pete's Avatar
118K and climbing. Motor is original along with everything in it.
The following 3 users liked this post by Sneaky Pete:
HBgreco (03-02-2020), janikphoto (02-29-2020), nobrand (12-30-2022)
Old 02-04-2013, 09:37 AM
Gator996
Gator996's Avatar
2000 996 with 119,000 current. Proactively replaced with LN dual row. Old bearing was good to go.
Old 02-04-2013, 09:38 AM
andys-944
andys-944's Avatar
2000 C4 tiptronic 110K original engine and bearing still going
Old 02-04-2013, 09:40 AM
jumper5836
jumper5836's Avatar
DD and tracked 2002 996 with 125k km. Proactively replaced with LN. Old bearing was good to go but need an engine rebuild (worn out cylinders).
sportbiker929 (09-28-2022)
Quick Reply: IMS bearing failure for your 996, Y or N? tell us (yr, 996 Mk1 or MK2 failure mode)
