FS: New Motec M800
FS: New Motec M800
Category: Engine - Electrical
Price (no $ sign please): $4200
Part fits (select ONLY those which apply): 911
Location (Region): West
Item Condition: Brand New
M800 Motec ECU, N.O.S., with “Advanced Functions” license (traction control, flat shifts, anti-lag).
Ignition Expander module
Harness for 911 Turbo
CAN interface cable
Retail on everything is $6700. Asking price $4250 + shipping.
Specs from Motec:
Basic Specifications
Outputs
· 8 x Injector outputs—high or low ohm ‡
· 6 x Ignition outputs ‡
. 8 x Auxiliary outputs—for functions such as camshaft control, drive by wire throttle, boost control, nitrous injection, idle speed stepper motor and many more
‡ Optional injector / ignition configurations:
(requires 10/12 Cylinder Sequential upgrade)
. 10 high ohm injector outputs and 4 ignition outputs
. 12 high ohm injector outputs and 2 ignition outputs
Inputs
· 8 x Analogue voltage inputs—fully configurable including custom calibrations
. 6 x Analogue temperature inputs—fully configurable including custom
calibrations
· 2 x Wideband Lambda inputs—for Lambda measurement and control
· 4 x Digital/speed inputs—for wheel speeds and function activation
Communications
· 1 x CAN
· 1 x RS232
Physical
· Case size 147 x 105 x 40 mm
· Weight 500 gram
· 1 x 34 pin and 1 x 26 pin waterproof connector with gold plated contacts
Pictures of the actual unit:
