993 Forum 1995-1998
Help: Recaro Pole Position install
Old 04-13-2011, 11:52 AM
tjangi
tjangi's Avatar
Default Help: Recaro Pole Position install
For those who have installed Recaro Pole Positions and still have the original seatbelts. Do I need a special bracket to mount the seatbelt to the floor/rail/bracket? As it stands, I cannot fasten the seatbelt at the original position.
If I do need this bracket, where can I purchase this?
Thank you very much for the help
Old 04-13-2011, 12:07 PM
ilko
Agent Orange
ilko's Avatar
IIRC I used the rear seatbelt receptors on mine, and bolted them to the mounting point of the bracket with the seat. Also you may want to run the seat belt through the outside lap belt hole. It will hold you in place better.
Old 04-13-2011, 12:12 PM
TAI2
TAI2's Avatar
Old 04-13-2011, 12:20 PM
ilko
Agent Orange
ilko's Avatar
Not sure on price, try Ebay and dismantlers for that. If you're getting used ones make sure they are from a 993 because the seat belt standards changed several times in the 90s.
Old 04-13-2011, 12:21 PM
ilko
Agent Orange
ilko's Avatar
Wow! I responded to your question but it was posted ABOVE your answer. Does that mean I can travel through time? Anybody want this coming Friday's Mega Millions numbers?
Old 04-13-2011, 12:22 PM
tjangi
tjangi's Avatar
How much are the rear seabelts receptors and "cheap" source, as I do need the rear to function for the kids.
Old 04-13-2011, 12:23 PM
ilko
Agent Orange
ilko's Avatar
Ah crap, I guess it's just a software issue. No PMs on the Mega Millions offer please...
Old 04-13-2011, 12:40 PM
CAHRERA
CAHRERA's Avatar
Ask for Al at www.partsheaven.com I'm sure they have it.
Old 04-13-2011, 01:49 PM
RDS928S
RDS928S's Avatar
Gappy,
you can have my rear seat belt receptors.
Im taking out the rear seats anyway.
Rich
Old 04-13-2011, 02:24 PM
Nollie
Nollie's Avatar
I used part 964.521.065.00 (RS tunnel side seat belt anchor) https://rennlist.com/forums/993-foru...-question.html with my SPG seats. Worked well.
Old 04-13-2011, 04:18 PM
e9stibi
e9stibi's Avatar
Brey Krause typically has what you need.
http://www.bkauto.com/
Old 04-13-2011, 05:30 PM
tjangi
tjangi's Avatar
Thank you for the help sofar. This is what I wanted to do. The L bracket goes under the rail and the receptor is attached to the L bracket. Thoughts?
Old 04-13-2011, 05:46 PM
Elonash
Elonash's Avatar
When using rear seatbelts receptor how to deal with the presence wire ?
(actually are there any presence signal taken on the front seats ? guess no from my couch...)
Old 04-13-2011, 05:48 PM
Bill Verburg
Bill Verburg's Avatar
Correct, you need another bolt though, also I used the rear seat belt receptacle too because I wanted mine down below the seat side hole so that there would be no interference w/ a 6pt harness. But one of the 997 receptacles might be a better choice if you don't run dual street/race setups, they come in several different lengths
Old 04-13-2011, 05:58 PM
Bill Verburg
These are the 997 receptacles
the whole shebang mounted in the car, you can see how low the 993 rear receptacle is
most of us mount the RS mount between the siderail and the slider, not under the slider, you want it to move w/ the seat
the whole thing assembled before installation
Quick Reply: Help: Recaro Pole Position install
