996 Forum 1999-2005
Foam in airbox
Old 01-04-2006, 01:46 PM
vove
vove's Avatar
Default Foam in airbox
Any of you guys take the foam located in the airbox under the filter to make the car sound louder? I've heard that you can take the foam out to give your car a little more roar but will this have any affect on the performance?
Old 01-04-2006, 04:04 PM
SPR
SPR's Avatar
there is no foam in my airbox.
Old 01-04-2006, 05:24 PM
vove
vove's Avatar
LOL..I thought so too but somebody I know personally did this and he told me that he took the foam or whatever out under the filter, now his car sounds a bit louder. Im going to check and take some pics to post.
I also thought to myself this must be the dumbest post that I've ever posted.
Old 01-04-2006, 05:48 PM
gpallem
gpallem's Avatar
No clue what you are talking about, really...but I'll give you my opinion anyway If there's foam in there, don't you think it may be additional filtering?
Old 01-04-2006, 06:04 PM
Tim Wasmer
Tim Wasmer's Avatar
Not in any of my 3 PCars...............
Old 01-04-2006, 07:47 PM
wross996tt
wross996tt's Avatar
If by foam you mean the foam that spilled out of your beer...yes it should be removed. There is no foam in the airbox...LOL.
Old 01-04-2006, 10:07 PM
mrcook02996
mrcook02996's Avatar
In my '02 there is some "foam" in the airbox. This "foam" is in front of the drain slits for the air intake. I assume this is to allow the water out but keep anything from entering through the drain. I don't know about any performance increase, but if everything else is stock it might seem to be slightly louder with it removed. Imo..I would leave it in, I recently found a couple of mice that had some how found their way into my intake, so for me the fewer holes the better.
Old 01-04-2006, 10:10 PM
bobporsche996
bobporsche996's Avatar
it's good way to get something you don't want in your engine in there.. leave any filtering/blockades on there.. not worth the risk.. if you want a loud car, get the fabspeed bypass for $400..
Old 01-04-2006, 10:31 PM
Vulture996
Vulture996's Avatar
This is located in the airbox, under the air filter and is a baffle to reduce sound
It's a sponge type material held in with a plactic bracket and 6 phillips head screws. Makes a minimal but noticable difference in sound, not performance.
Old 01-05-2006, 01:01 AM
vove
vove's Avatar
This mod reminds me of the people drilling holes in their 964's airbox for extra sound. Simple yet effective if one is looking for more roar in your 996. Thanks for the pic Vulture.
Old 01-05-2006, 08:55 AM
nycebo
nycebo's Avatar
That looks very interesting. I may have to tool around over the weekend and check it out. Of course, if Porsche had really wanted some proper dampening, I'm surprised that they didn't go with Dynamat or a more proven product. Foam? Hrmph.
I have no response for that.
Old 01-05-2006, 03:28 PM
Vulture996
Vulture996's Avatar
I'm close with the crew over at TPC. This is one of their suggestions.
I did it, sounds a little better.
Old 01-05-2006, 06:07 PM
Russ Murphy
Russ Murphy's Avatar
Is that the "airbox muffler" that gets deleted when you get a Fabspeed or Schnell intake mod kit?
Old 03-30-2008, 10:49 AM
perryinva
perryinva's Avatar
OK, I found this thread which sort of answers my previous question...it appears to be for noise. Appears different years don't have it..(mine is an 02 C2) There is a small, maybe 1/4" drain hole under it, not enough to worry about mice, for sure. While searching , I found lots of references to the airbox being sealed. In mine the right rearward quadrant has maybe 60 small maybe 1/8" holes drilled in (factory drilled, not owner) so it is most defnitely NOT sealed...anyone know when this occured or why?
Old 10-26-2017, 03:05 PM
mrjonger
mrjonger's Avatar
Haven't seen any newer threads on this. Based on this thread and one in Renntech, I'm just going to remove the foam in my airbox. Mine's really brittle and I'd rather not have it circulating.I can't find the specific part number just for the foam.
It's the foam in the upper half of the box. Popular vote is that it just dampens sound. Any one have any updates on what this foam does and whether or not it's important?
Quick Reply: Foam in airbox
