I know a 992 Carrera 911 is an expensive vehicle. I realize we’re supposed to know what we’re getting into when we buy one of these vehicles.
However, coming from a guy who grew up working on his own cars—many times fixing problems on the side of the road, I have a problem with paying $1800 to change PDK transmission fluid and $1200 to put in new spark plugs.
Maybe are others here who have the same feelings, but I remember buying cars for my children that didn’t cost what these two maintenance items will cost.
So, my question is whether these charges seem out of line and, regardless of that, do people here tend to go to trustworthy private shops as an alternative to the dealer? Does anyone here actually challenge either of these two maintenance items themselves?
...However, coming from a guy who grew up working on his own cars—many times fixing problems on the side of the road, I have a problem with paying $1800 to change PDK transmission fluid and $1200 to put in new spark plugs
You should be it yourself? You will need the tools and the knowledge.
With Dealer labor rates somewhere around $300-500 per hour depending on your location...yes servicing these cars is expensive.... but that should not come as a surprise to any high-end vehicle owner.
Spark plug changes are every 30K miles or 4 years, and PDK fluid change is every 120K miles or 12 years, so these are not yearly or even every other year maintenance routines.
If you compare with an independent shop...prices will be lower...but not much lower.
You can perform these items yourself, but a spark plug change in itself is probably a 2.5 - 3.5 hour job. That's the labor for a dealer tech with all the tools and a lift.
Check out what's needed for a home spark plug change....
For a PDK oil change...there are actually 2 types of maintenance required at different mileage...a 60k PDK clutch oil chance and a120K PDK oil change...I'm sure there is info out there for a home mechanic to complete the PDK service.... but again, I understood the cost of servicing, or I would have bought a different car!
If youre even somewhat mechanically inclined, buy the tools and DIY. DIY all day. You save time, money, gain knowledge and experience plus is satisfying.
When you walk into a Porsche dealership and see the fancy building and number of people they employee, how do you think they can afford all of that?
Yes, there are plenty of people who use qualified and trustworthy independent shops, DIY, or combination of all. There are plenty of resources online including videos on YouTube showing you how to perform all sorts of maintenance and repair tasks. None of the routine maintenance tasks are rocket science. You can learn how to do them yourself if you are inclined. All tools including Porsche scan tools can be purchased by anyone.
Regarding the OP's specific question, I've done plug changes on each NA 911 that I've owned previously. (4) The 992.2 is my first turbo and the additional plumbing and complexity as well as my reduced dexterity, will see me at the dealer for the next one. Just an accepted cost of owning a modern Porsche.
Yes, a PDK fluid change is expensive, but I've never owned a PDK car long enough, or put on enough miles, to warrant replacement fluid. I don't expect that to change.
Oil changes are another matter. Aside from the ones that have been free, I've done every oil service on my 911's over the years. It's so easy, there's really no reason to complain about dealer prices for that item.
Those are some cheap quotes, be glad they dont charge you $3000 for spark plugs.
Whats the additional complexity? Is it same as 992.1 turbocharged 911 spark plugs or is this more complex due to e turbo?
From: US Southeast: South FL and part-time Upstate SC
Why hasn’t anyone mentioned the engine oil change for $699? That’s the worst of all.
It wasn’t so long ago there was no Porsche tax. Back in the 996 days (and dare I say 993), Porsche in general was a secret and the service departments were thrilled to have people come and use the shop for service; and prices were very normal and frankly low. After Covid the prices have gone into the stratosphere and frankly it’s legalized robbery and a disgrace.
I don’t even do my free engine oil changes offered by brands of any of my cars (count ‘em 17) at the Dealer. I change all engine oil myself as well as other minor service. It’s something I have come to enjoy and I actually follow all factory procedures and utilize a device called a torque wrench which is a thing Dealer “technicians” (mechanics?) consider an insult to utilize.
As I said in my post, I've always had NA 911's up through a 2014 GT3, until my current turbocharged 992.2.
So, I was comparing changing the plugs in a normally aspirated 911 to changing them in a modern twin-turbo engine which is generally more complex and crowded than a NA one, making the plugs harder to get to.
They also have to make up for all the lost maintenance on those EVs they are pumping out to keep the lights on. Our son has a Taycan CT that he was quoted something like $1200 for cabin filters and wiper blades. He ordered the OEM parts online and did it himself in well under an hour.
A few weeks later he took it in for a seat recall of some sort and they called and said he needed new wiper blades. They were quiet when he said they should check again as he just changed them 3 weeks ago…
