View Poll Results: Is the 718 GTS 4.0 the modern 997 alternative?
Yes1 NA goodness, similar weight & length
6
66.67%
No! A Cayman is never like a 911, the engine is in the wrong place!
3
33.33%
Voters: 9. You may not vote on this poll
Old Apr 28, 2026 | 02:54 PM
912E's Avatar
912E
Default Is the 718 GTS 4.0 the modern 997 alternative?
I got to drive a 718 GTS 4.0 6MT the other day and thought it felt a lot like the 997 Carrera S 6MT, so I did some LLM comparing and it seems like if you compare 6MT to 6MT the performance and dimensions are quite close (The PDK was improved over the years, so the GTS is a lot quicker to 60 in PDK).
To me the difference was the 718 felt a bit less floaty even with the suspension raised 10mm per the bulld sheet, and I dont know the technical term for it but I felt more "one with the car" in the twisties. The 997 was more fun to downshift and accellerate, felt less planted and modern but in a good way- could have been the tires...
All this to say, maybe if you're having trouble finding a 997, you should consider a 718 GTS 4.0
Would love to hear opinions.
Side-by-Side Comparison:
Engine:
• 997.2 C2S: 3.8L Flat-6 (NA)
• 718 GTS 4.0: 4.0L Flat-6 (NA)
Layout:
• 997.2 C2S: Rear-Engine, RWD
• 718 GTS 4.0: Mid-Engine, RWD
Power:
• 997.2 C2S: 385 hp / 310 lb-ft
• 718 GTS 4.0: 394 hp / 309 lb-ft
0-60 (6MT):
• 997.2 C2S: ~4.5s
• 718 GTS 4.0: ~4.3s
Weight:
• 997.2 C2S: ~3,275 lbs
• 718 GTS 4.0: ~3,165 lbs
Steering:
• 997.2 C2S: Hydraulic
• 718 GTS 4.0: Electric
Length:
• 997.2 C2S: 174.6 in
• 718 GTS 4.0: 172.4 in
Old Apr 29, 2026 | 01:57 PM
RJ80's Avatar
RJ80
This is an excellent example of numbers not telling the whole story of a car. A base 987.1 Cayman, for example, has power, weight and dimensional figures that are comparable to a 964 Carrera 2, but the driving experience is vastly different. And this without mentioning aesthetics and era of origin which are a huge part of an emotional car purchase. But it can be a fun exercise to compare models like this.
