Track Tire size questions for Cayman
Old Apr 24, 2026 | 10:34 PM
todinlaw's Avatar
todinlaw
Default Track Tire size questions for Cayman
I recently bought a 2010 Cayman for track duty and am trying to find a suitable 200 treat-wear tire that will fit on my 18 inch rims and not throw off the ABS or other issues.
The original size is front 235/40/18 rear 265/40/18; front diameter 25.4& rear 26.3 front rims 8" rear 9"
Looking to see if i can fit a set of RE-71RZ tires they have the fronts 235/40/18 but the closest rear diameter tire is a 275/35/18 tire that is smaller at at 25.6.
Wonder if anyone has ran that combo on a Cayman base without any ABS issues?
Thanks Frank.
Old Apr 25, 2026 | 08:56 AM
86-951's Avatar
86-951
I've been running 255/35 (25" dia) and 275/35 (25.6") on 18's for years, autox and track days on a 2011 S. Never a peep from the PSM or ABS. The extra front width also gives a little more bite. Mostly Bridgestones. I am running a 10" wheel in the back though.
Old Apr 25, 2026 | 03:45 PM
jesseellington's Avatar
jesseellington
Default Same here
Never had a problem with those sizes on my 08 S.
Old Apr 25, 2026 | 09:03 PM
todinlaw's Avatar
todinlaw
did you get any tire rubbing up front? are you on stock suspension? I would think that the 275's should work on the 9 inch rims that i have in the rear. Not as good at 10's but not ready to jump into the deep end of the pool on total track set up.
Old Apr 26, 2026 | 09:24 AM
86-951's Avatar
86-951
No rubbing.
Old Apr 27, 2026 | 11:19 AM
Das Borgen's Avatar
Das Borgen
I sent you message on Facebook, Frank
Old Apr 27, 2026 | 12:35 PM
David Mackintosh's Avatar
David Mackintosh
I'm running R-S4s on track in 245/40 and 275/35 on my 2.9L, camber is -2.0 at both ends, with SPC adjustable front LCAs and a 22mm RSB. I don't think the ABS is very sensitive to small changes in f/r tire diameter, although larger changes would affect the braking balance.
