AC Servo Fault Codes
Old Apr 21, 2026 | 03:13 PM
Ryan Snellen's Avatar
Ryan Snellen
7th Gear
Default AC Servo Fault Codes
I've read myself cross-eyed trying to find out how to replace the passenger side servo motor on my 04CTT. The symptom is hot air coming out of the dash vent on PX side, cool on the driver side. When I close the passenger dash vents, the driver side get hotter so the hot air is bleeding into the driver side (LHD).
My AC codes are:
2100 - Footwell flap
2101 - side blower
1810 - drive motor temp valve
710 - defrost flap
1299 - implausible signal
I have an Alpine 507 stero installed which is the cause for a few other implausible signals elsewhere so I'm less concerned there unless I am optimistic in my assessment. All I have been able to locate on the PX side is the bottom most servo; the footwell servo I believe.
I'm looking for direction on how to replace the servo, ideally with pix, and welcome any other feedback. I'm sure there is a link out there detailing this procedure but I have not gotten the correct search query to populate.
Thank you in advance.
Old Apr 22, 2026 | 09:43 AM
Klaird928's Avatar
Klaird928
It may not help, but here is a picture of the whole AC unit out of the car. The top one as you can see is tough to get to even with the unit out of the car.
Old Apr 22, 2026 | 11:10 AM
Jerryallday's Avatar
Jerryallday
5th Gear
What scanner did you use to read the ac codes? I have a clicking flapper noise behind the radio somewhere
Old Apr 23, 2026 | 07:55 AM
Ryan Snellen
7th Gear
Hi Jerry. I have the Durametric.
Old Apr 23, 2026 | 08:07 AM
Ryan Snellen
7th Gear
Thanks KLaird! I had my eyes set on the passenger far righthand side. When I pulled the glovebox, I see the one you've posted here.
For first time servo-seekers, this is center right of vehicle. Straight forward from here I suppose with very tight working room.
