Changed the oil on my 991.2…
I’ve always changed the oil myself on all my Porsches. The most difficult/messy was my 2013 Boxster and the easiest is my current 991.2. This my first Porsche with the oil filter canister on the top of the motor. If I didn’t have to wait for all the oil to drain I could do it in 30 minutes.
While the oil is draining from the sump, crack the canister cover loose to help that drain out a bit. The whole ordeal shouldn't really take you longer than 30 minutes if you're moving purposefully.
