Persistent P0121 Code on 2006 Porsche 987 Boxster S
Old Today | 01:38 AM
UltimateTankOwl's Avatar
UltimateTankOwl
2nd Gear
Default Persistent P0121 Code on 2006 Porsche 987 Boxster S
Hello everyone,
Recently I have encountered a persistent P0121 error on my car which my scanner lists as an accelerator potentiometer out of range code and the car has very sluggish acceleration. I connected my foxwell and read that my max throttle angle at this point only opens to about 17% and it looks like my car is only going up 1 mile per second when I am flat out.
So far, I have replaced my gas pedal assembly, cleaned my MAF sensor and throttle body with no success. My next plan is to disconnect the battery for a little bit to reset the DME so I can recalibrate the pedal again. I will also look into my fusebox and see if there are any issues there or any loose relays as I was poking in there shortly before I had this issue.
Has anyone else seen an issue like this before? Sometimes it comes and goes when I restart my car but it has been more frequent as of recently. There are some times when the issue disappears for a time but just returns out of nowhere. I did look at the throttle angle position sensor and noticed that sometimes the throttle hits 100.3-101%. I don’t know if this is causing the issue or not but I don’t know if that reading is okay or not. Please help me.
Old Today | 09:14 AM
mauricedv's Avatar
mauricedv
In addition to the accelerator pedal potentiometer, there is another inside the throttle body. If you turn on the ignition without starting the car and wait about a minute, the DME will automatically calibrate the two potentiometers. You should hear the throttle actuation noise coming from the engine.
Old Today | 12:39 PM
UltimateTankOwl
2nd Gear
I hear it actuate once or twice as soon as it is in accessory for a little bit but it doesn’t flap as much as it used to. I am not sure what it does to calibrate the throttle body so I don’t know for certain if this is normal or not.
