996 Forum 1999-2005
01 996 C4 front differential fluid
Old Apr 18, 2026 | 05:53 PM
Viper1000's Avatar
Viper1000
Default 01 996 C4 front differential fluid
I don't think the front differential fluid has ever been changed in my 01 996 C4 and wondering what type of fluid everyone uses? Looks like SAE 74W-90 GL-5 and it takes .95 quarts?
Old Apr 18, 2026 | 08:05 PM
NOTA968's Avatar
NOTA968
Just did mine. Mine took a little more than a liter. Used this:
Old Apr 19, 2026 | 05:56 AM
Wordstop's Avatar
Wordstop
It's 75w90 oil (I use porsche classic) and in European terms takes 1.5 litres
Old Apr 19, 2026 | 09:31 AM
Viper1000's Avatar
Viper1000
According to ChatGPT: Mobile 1 Synthetic Gear LS 75W-90 is the common choice so thats what I'll go with. I'm not racing that car, only a weekend driver so that should suffice! Thanks for all the replies!
Old Apr 19, 2026 | 08:38 PM
yvvvz's Avatar
yvvvz
Like NOTA968, I went with the Mobilube PTX 75w-90. From my research, the PTX designation was important.
Old Apr 19, 2026 | 11:40 PM
yvvvz's Avatar
yvvvz
To expand on Satur's comment, always open the fill hole first. One, for good venting without bubbling during draining. Second, you want to make sure you are going to be able to get the fill hole open BEFORE you drain out the fluid! It would be quite a pickle to drain the fluid out and then find you can't refill.
The rear drain plug on my differential was on incredibly tight. Really, really tight. I was very worried I would round the head of the drain bolt or break it. It required a long breaker bar and I had to be careful to make sure the socket stayed firmly engaged to the head of the bolt. It wasn't easy to do with the car only up on jack stands. Hopefully, you will not have a similar issue.
