PIWIS Question - Max RPM Reached for PDK
Old Apr 18, 2026 | 02:29 PM
3-Pedals's Avatar
3-Pedals
Default PIWIS Question - Max RPM Reached for PDK
Does anyone know where I can find the max RPM reached for a PDK car? The Z angle section in DME that usually shows overrev ranges for manual cars dont have this value for PDK cars.
Old Apr 18, 2026 | 03:31 PM
ldamelio's Avatar
ldamelio
Base and S 992.2 PDK redline and limit at 7500 rpm. There are soft limiters in neutral that hold it significantly lower - somewhere south of 4000.
Old Apr 18, 2026 | 06:33 PM
3-Pedals's Avatar
3-Pedals
I am not asking about the redline. I am asking about how to see max rpm reached in PIWIS.
I have a new car that I am babying and I want to see if previous owner exceeded the 7000 rpm (its an SRS with 9000 rpm limit).
Old Apr 18, 2026 | 06:51 PM
dixonk's Avatar
dixonk
Veteran: Army
DME - actual values. Z angle and range 1, 2, 3, and hours. Same as a Manual car. If it shows 0 for range 1 then it never went above 9k
Old Apr 18, 2026 | 07:06 PM
3-Pedals's Avatar
3-Pedals
It shows 0 but there should be a way to see “max rpm” reached, no?
Old Apr 18, 2026 | 07:09 PM
dixonk's Avatar
dixonk
Veteran: Army
I don’t believe it will report values under range 1. @rnlst_log any input?
Old Apr 18, 2026 | 07:10 PM
dixonk's Avatar
dixonk
Veteran: Army
And if anyone is wondering yes it is possibly to get a range 1 on PDK. If you unload the rear wheels while at max rpm it will overrev. I hit the afterburners on mine before lol.
Old Apr 18, 2026 | 08:11 PM
3-Pedals's Avatar
3-Pedals
Maybe I can do a VAL and search for it there.
Old Apr 18, 2026 | 09:31 PM
dak656's Avatar
dak656
can confirm range 1 is possible on pdk.
I do not see max engine speed on VAL or anywhere else (manual or pdk). Not that it isn't there... I just can't find it.
