Icarsoft air suspension question
Old Apr 14, 2026 | 06:59 PM
Shuga's Avatar
Shuga
Default Icarsoft air suspension question
Anyone have a link on amazon for a icarsoft scan tool that can recalibrate the air suspension on a 957 GTS?
Old Apr 14, 2026 | 07:02 PM
Shuga's Avatar
Shuga
Wasn't sure if this one could do it?
Amazon Amazon
Old Apr 15, 2026 | 07:00 PM
Shuga's Avatar
Shuga
Anyone?
Old Apr 16, 2026 | 05:12 AM
drfred's Avatar
drfred
It cannot calibrate the air suspension. For that you need PIWIS, Durametric or perhaps a Launch can do it.
Old Apr 16, 2026 | 06:07 PM
Shuga's Avatar
Shuga
Dam
Old Apr 16, 2026 | 06:20 PM
ekstroemtj's Avatar
ekstroemtj
Originally Posted by Shuga
Dam
what means calibrate ?
i am using this device. as far as i remember you can do it manual. you have to set the hight in mm for all 4 corners into the OBD device and it should work
Old Apr 17, 2026 | 11:13 AM
Shuga's Avatar
Shuga
Hmm. So we have one person saying it'll work and another saying it won't lol. Who's going to be the tie breaker haha
Old Apr 26, 2026 | 02:21 AM
VoilaGT3's Avatar
VoilaGT3
Veteran: Army
lol, well here's my little bit of experience aka 2 cents.
I used my i-Carsoft Porsche 3 to deflate and fully inflate front and rear to test after replacing two release valves.
Old Apr 26, 2026 | 03:04 PM
Shuga's Avatar
Shuga
I'm going to order one and report back lol. Do you have a link to the one you used?
Old Apr 28, 2026 | 05:29 AM
Caesium's Avatar
Caesium
My Autel can calibrate the suspension, you should only do that if you have replaced a component though.
The Porsche calibration isn't like a Range Rover.
Old Apr 29, 2026 | 05:09 AM
VoilaGT3's Avatar
VoilaGT3
Veteran: Army
iCarsoft USA
Old Apr 29, 2026 | 03:54 PM
blaino's Avatar
blaino
I have the iCarsoft 3.0, the Launch Elite and Otofix D1 Lite. All three can calibrate the suspension, however the iCarsoft is by far the worst/least capable of the three. For basic stuff, reading codes, clearing faults, etc. it's totally fine, but that's really where it ends. The Otofix is by far the best of the three and has way more capability, albeit for a little more money, but the extra cost is well worth it.
Calibration can be a pain to get dialed perfectly, but you just need to be persistent and take good notes on the numbers you input.
Old May 2, 2026 | 01:55 PM
VoilaGT3's Avatar
VoilaGT3
Veteran: Army
lol, good to know, after many threads and questuons I have never heard of Otofix. Will keep in mind for the future. Currently making a PIWIS setup
Old May 3, 2026 | 11:56 AM
VoilaGT3's Avatar
VoilaGT3
Veteran: Army
Here is the option screen. hth
Old May 4, 2026 | 03:34 PM
blaino's Avatar
blaino
I also have a PIWIS 3 but only bust it out when coding or calibrating. The PIWIS 3 is sloooowww on a 955/957. If possible, I would build it with a PIWIS 2 unless you have newer Porsches you're also planning on using it with. But for 95% of things, the Otofix has been great. It's an Autel product and uses their technology.
