992 Turbo and Turbo S 2019-Current
2022 Turbo S with 7000 miles
Old Apr 13, 2026 | 06:54 PM
B Russ's Avatar
B Russ
Default 2022 Turbo S with 7000 miles
So 4 years in and foolishly low miles, dealer is hitting me up for 4 year service. Its had oil changes so I dont really think there is much to do beyond a brake flush. Your thoughts?
Old Apr 13, 2026 | 08:42 PM
Rocket_boy's Avatar
Rocket_boy
I'm just about like you - 2022, 6,700 miles. Went into the dealer a couple of times last year for an intermittent cluster error - was still in warranty. At that time the service manager brought up the 4 year service for over $4K Included new spark plugs, air filters, cabin filter, brake flush, on and on. Now normally I do all my own maintenance as I have all the lifts, tools and scanners - but seriously, do all of this at 6,700 miles? - please. I guarantee they'd be replacing plugs, filters and such that look near brand new. With 30 or 40K on the clock, sure some merit. Since it was already there I had a brake flush done which was reasonably priced. The cluster errors appeared to have been a slightly low voltage issue with the battery - started the car just fine, but some of the other modules didn't like it. Since it was 4 years old - I had them replace and code it. Normally batteries of any type don't last more than 4 years in Texas. So I'm pretty pragmatic about my ownership - if it needs it, it gets it, but I'm just not doing a blanket parts swap of good parts for good parts for no reason. Had them do all TSBs and upgrade the PCM / car module software. Little over $2k total - but that's all that needed to be done.
Old Apr 13, 2026 | 09:04 PM
Tief Lernen's Avatar
Tief Lernen
Subscribed! In a very similar situation with 2022 Turbo S I bought last year. Had just 1500 miles on it. Now almost 6k but I agree the spark plug service seems like overkill.
Old Apr 13, 2026 | 09:30 PM
Ensoniq's Avatar
Ensoniq
My 4 year 40,000 miles service was done last week for $2800 (plugs were done at 3 years)
I’m at 13000 miles
pretty reasonable for a 1/4 million dollar car in my opinion
Old Apr 13, 2026 | 11:10 PM
B Russ's Avatar
B Russ
Every tech I spoke with has said the same thing, mileage is the key for plugs not time. Ill have to take mine in for the windshield gasket this summer so Ill probably do the brake flush at that time as well, perhaps check alignment too.
Old Apr 13, 2026 | 11:11 PM
B Russ's Avatar
B Russ
Was that the Li battery
Old Apr 14, 2026 | 10:16 AM
Rocket_boy's Avatar
Rocket_boy
Yes - it seemed to start the car just fine (current / amps) but the voltage drop during a start was a bit low - making a few modules complain. After the change it seems to be fine. There are some kits to convert it from the Li battery to a more conventional, cheaper AGM battery albeit a bit heavier. I chose to just renew it with the same Li version to keep it original as it came.
Old Apr 14, 2026 | 10:37 AM
eclou's Avatar
eclou
2022, 16k miles. They just did mine as the 10k mile service, all for free including plugs
Old Apr 14, 2026 | 10:38 AM
neil.schneider's Avatar
neil.schneider
I was under the impression that the lithium iron batteries were actually better and longer lasting. Is that not true?
I was told that the spark plugs were also a matter of mileage, not time.
What does Porsche charge for a brake fluid flush? I already did the oil change at a local shop.
Old Apr 14, 2026 | 11:38 AM
Rocket_boy's Avatar
Rocket_boy
Not according to some research I did and talking with my service manager. Seems they are a bit of a crap shoot - with some only lasting 2/3 years - and some past 5. I always keep my car on a maintainer, but drive it as often as possible - so wish it would have lasted a bit longer, but 4 years and some months is OK in my book. I believe the TTS was one of the first cars to have an Li battery - and I'm sure there have been improvements since. There's not too much to decay on a spark plug due to age, mileage IS key. If I took mine out @ 6.7k miles - they would look almost brand new. I just don't like to waste parts or money. The brake flush was around $350 - decent in my mind for a TTS.
Old Apr 14, 2026 | 01:09 PM
B Russ's Avatar
B Russ
There seems to be many issues with the Li batteries from Porsche. The AGM Banner batteries I had in other P-cars were great. I just swapped out my 18 Panamera OG battery, after 8 years and the only reason I did was during a battery test I did it said full charge but battery health was Poor. Figured I got more than the expected use out of it. When I start seeing any battery issues in the 22 Im going with the conversion kit and probably another AGM. I haven't looked at the brake fluid res to see how the fluid looks, if its not cloudy at all then its fine.
Old Apr 14, 2026 | 01:24 PM
Angryinch's Avatar
Angryinch
I do not think this is what they're concerned about with the plugs.
I believe it has to do with no thread lube and the aluminum threads seizing into the spark plug threads.
The plugs themselves are fine, very likely.
The brake fluid flush is cheap, $350 cdn. They have a machine that flushes it out in one motion, very easily.
The plugs, you could probably push that service a bit, especially outside of warranty, but I would error on the side of caution. (Ive changed mine twice now, 28,000km)
Old Apr 14, 2026 | 04:11 PM
B Russ's Avatar
B Russ
I think your talking about galvanic corrosion from dissimilar metals. 10 years in the P car game and I haven't heard of this yet with the plugs. Not saying Im going 10 years but I dont see it as a major concern. Ill have to make a decision at some point as 30,000 miles is probably a good 4 years away at the current use pattern
Old Apr 14, 2026 | 04:22 PM
B Russ's Avatar
B Russ
Have to ask, how did you pull that off for free?
Old Apr 14, 2026 | 04:51 PM
luv2sleep's Avatar
luv2sleep
Ahhh, the good ole spark plug change debate! From my experience, I’d go with miles vs. time, unless you have a highly modded car. I swapped out the plugs on my R8 at just shy of 5 years with under 10k miles and all 10 plugs looked practically brand new.They were very easy to remove and were factory torqued to around 25-30 Nm. Spark plugs will not seize to aluminum cylinder heads unless there’s something else going on inside. At the end of the day, do what helps you to sleep at nights.
