Sponsored By:
Sponsored By:
Knocking from rear passenger side?
Old Apr 8, 2026 | 03:08 PM
bw1999's Avatar
bw1999
Default Knocking from rear passenger side?
I've tried to find someone with a similar problem on Rennlist so bear with me if this covered somewhere.
I have a relatively new to me 2014 Cayenne Turbo S with about 90k miles purchased in July 2025. I did a Fabspeed secondary cat delete when I bought it.
Recently had the air compressor and manifold replaced, followed by the front and rear air shocks replaced. This was done piecemeal to try to address an issue with the air suspension, and since all parts were replaced, the air suspension works well. However, after the compressor was replaced, when I went to pick up the car from the mechanics, I heard a fairly loud knocking coming from the rear passenger side (as best I can tell) when first pulling away that then resolved and didn't return until the next morning. I only hear this noise when the engine is under load (so the car is moving) and not when I rev the engine when sitting idle. I also have not heard it when revving the engine in neutral when the car is moving. It tends to come up around 1500-2000 rpm, and it definitely goes away in a few minutes. When I hear this noise, I don't notice the car driving any differently, I don't notice the "crunching/grinding" noise people have described when the transfer case is shot.
I had the mechanic drive with me yesterday and they did hear the sound. They then put the car on the lift and could not replicate the sound when revving the engine because it only happens when the car is moving. They (and I) checked under the car and did not see anything loose or knocking.
They mentioned it could be the exhaust itself (as in interior baffles), which I would be happy to replace with a Fabspeed Maxflow exhaust if I knew it would fix the noise.
So, any ideas of what this could be? Initially thought it was something to do with the suspension work or something that was disconnected, but neither the mechanic nor I can find anything that would be related. Or any ideas of how to confirm it is coming from the exhaust or elsewhere?
TIA
Brian
Old Apr 8, 2026 | 03:21 PM
v10rick's Avatar
v10rick
Others have used a go pro with a magnetic mount to locate odd sounds.
Old Apr 8, 2026 | 10:03 PM
gmsomerville's Avatar
gmsomerville
The first thing I would check (because it’s easy) is the driveshaft center support bearing. Car 12 years old, 90k, plentiful torque. Prove that’s not the problem first.
If it’s failing the noise couid sound like it’s coming from that area. Only moving and under load would sound about right. Mine went away after about 10 minutes driving but I wasn’t satisfied it was nothing. Glad I persisted.
Old Apr 8, 2026 | 11:14 PM
bw1999's Avatar
bw1999
That's a great idea. Just bought some chassis ears!
Old Apr 8, 2026 | 11:16 PM
bw1999's Avatar
bw1999
This makes more sense than the exhaust. We certainly looked and felt around but the chassis ears will help I hope. Thanks for the suggestion,
Old Apr 9, 2026 | 12:54 AM
garrett376's Avatar
garrett376
Unplug your rear differential control unit, and see if it keeps happening.
Old Yesterday | 12:48 PM
bw1999's Avatar
bw1999
An update: was able to use chassis ears and it definitely sounds like it's coming from the exhaust. My mechanic also was able to induce the knocking sound when it was on a lift and said it's definitely coming from the exhaust. He tried to use a boroscope in the exhaust but wasn't able to see anything broken but next step is replacing the exhaust with a Fabspeed unit and see if that fixes the problem!
