993 Forum 1995-1998
Smoke Test for Vacuum Leaks - N00b
Old Apr 1, 2026 | 03:19 PM
estrei's Avatar
estrei
Default Smoke Test for Vacuum Leaks - N00b
I've got a few CELs on my 1998 cab related to vacuum issues. I borrowed a friend's smoke testing machine, and I'm stuck with what's next.
Could you share a good walkthrough for testing vacuum leaks?
I've checked youtube, the DIY forum, the technical pages at PCA, etc. Maybe I'm missing something! The videos found are earlier 911s that look a little different. I think I take off the airbox (done), and plug some other lines (which ones??) Get me started and I'll put together a video on how to hook it up for the next guy!
estrei's Avatar
estrei
Photo of old glory for good karma
Old Apr 1, 2026 | 09:23 PM
TheOtherEric's Avatar
TheOtherEric
It’s described in the shop manual. Then just go to Home Depot and get a big rubber cap, drill a hold in it, insert a bike valve, then attach it in place of your air box. Add air at the valve and listen for leaks. No smoke needed.
p.s. you’re not talking about a vacuum leak, but rather an intake leak. Two totally separate systems, parts, symptoms, tests, and fixes.
Old Apr 1, 2026 | 11:23 PM
estrei's Avatar
estrei
Thanks for the nudge. I've just downloaded the workshop manual and am overwhelmed with knowledge. This is incredible.
You have me second guessing my test. Experiencing rough idle, occasionally high idle, and codes:
  • P1124/P1126 - Fuel/air lean
  • P0410/P1411 - SAI
OpenAI suggests to start with "Vacuum Leak: A large leak in the intake system, cracked vacuum lines, or a bad oil filler cap seal. Perform a Smoke Test: This is the most effective way to identify vacuum leaks in the intake or SAI system"
Perhaps thats 2x different tests? One on the intake side, and one on the SAI system?
Old Apr 2, 2026 | 12:42 PM
Churchill's Avatar
Churchill
Smoke testing the intake is very simple. Remove the airbox (the black plastic housing the air filter sits in). Cover the end of the MAF with a shop glove (latex, etc). You'll have to put a big rubber band around it to hold it on. Then plug the smoke in. At the center rear of the varioram manifold (closest to you when you're standing behind the car) you'll see two rubber fittings sticking off the left side. One has a vacuum line, the other is just a cap. Pull the cap off and plug your smoke in there.
Old Apr 2, 2026 | 02:15 PM
alsamrob4's Avatar
alsamrob4
Had similar issues. Have you cleaned your idle stabilization valve? Simple to do. https://p-car.com/diy/isv/
The P0410/0411 likely means that you need you SAI check valve replaced (best outcome) or the system cleaned out (more work). There are many "How tos" for this, but this is a good start. https://p-car.com/diy/sai/1/sai.htm
Old Apr 2, 2026 | 02:35 PM
TheOtherEric
First off, ignore anything AI says; that's a completely useless waste of time.
Second, get the special PDF document "On-Board Diagnosis" specifically for P1124/P1126 faults. I'll try to upload, but no idea if it'll work.
Third, if that didn't help, review the diagnostics/symptoms table (Section 24 of "DME Diagnosis") to match your symptoms to what tests are called for. And see Oxygen sensor issues there too.
If you test the intake system for leaks-- it is covered in either that P1124/P1126 document or the shop manual Section 24 of "Fuel System, Electronic Injection." Those docs show a cover plate but you can go to Home Depot and get a mixture of PVC caps, rubber sleeves, hose clamps, and a tire valve to make it yourself. Easy peasy. Pressurize to 7 psi and listen for leaks.
It’s not too hard. You got this.
Old Apr 2, 2026 | 11:49 PM
estrei's Avatar
estrei
God I love you guys. This .pdf is incredible. If you're ever in Chicago, I'll owe you a beer!
Edit: Actually you are in Chicago! What part? I'm way out in Geneva (Western burbs) and could use some Porsche friends. Do you get to events, tracks, cars+coffee etc? I am also looking for a friend to turn wrenches with occasionally, but I think we might be in very different leagues of skill
Old Apr 4, 2026 | 10:46 AM
TheOtherEric
I’m out west as well. I don’t get out to events much but I’d like ti change that. My wrenching days are mostly over (cars is how I like it, and now I pay others to do the hard stuff) but I’m always happy to consult. Which means:
Old Apr 4, 2026 | 10:58 PM
coreseller's Avatar
coreseller
Thanks for that Eric, Very Nice.....
Old Apr 28, 2026 | 04:31 PM
estrei's Avatar
estrei
This was easy. Smoke initially came pouring out of the MAF. I covered it with a glove as suggested, and I couldn't find any additional sources of smoke.
File Type: mov
Old Apr 28, 2026 | 07:55 PM
Bill Verburg's Avatar
Bill Verburg
The vac leak that's often missed is up in the dashboard area from the HVAC actuators
Old Apr 29, 2026 | 03:47 AM
TakeFour's Avatar
TakeFour
Yes, especially if any work has been done on stereo etc
Old Apr 30, 2026 | 09:02 PM
TheOtherEric
Not sure why the talk about a vac system leak when the OP’s codes are due to intake system leaks. Totally different. Can a vacuum system leak cause codes? Maybe if a line near the engine became totally unattached but a failed HVAC actuator probably wouldn’t throw a code. Shop manual doesn’t bring up vac system leaks as a possible code causer.
