VR Tuned ECU Tuning Box Porsche 991 Turbo S 3.8L 2014-2020
For SaleEngine - Power Adders
Get your Porsche 911 (991) 3.8 Turbo S tuned with the Version 2 tuning box kit from VR Tuned. The tuning box kit is a plug and play solution to boost your vehicles performance up like an ECU flash, but without affecting your warranty
This will work on both Turbo and Turbo S.
Features:
• Bluetooth control supported on iOS & Android:
◦ Change between 7 performance maps via Bluetooth app control
◦ Enable or disable Tuning Box function ( ON or OFF )
◦ Apply and adjust a warm-up timer allowing the vehicle to come to running temperature before performance settings are active
◦ Set 3 custom driving modes ( Race, Sport & Eco ) to each setting you desire for quick selection
• Made in Germany
• Plug and Play for easy install and removal
• No detection by dealer when removed
• Up to 7 different maps for easy programming
• Includes bypass plug to run as stock
• Does not lock to vehicle or VIN
• Harness has OEM style connectors, no splicing or cutting
• Digital Microprocessor Controlled
• Proven power gains tested on 93oct/98ron.
• Designed for forced induction vehicles only
• Tuning box cannot eliminate CELs caused by modification or removal of emissions control devices such as catalytic converters.
