991.1 GT3 Paddle Shifters - A Fix That Went Deeper Than Expected
Old Aug 3, 2025 | 02:49 PM
Hank Cohn's Avatar
Hank Cohn
Default 991.1 GT3 Paddle Shifters - A Fix That Went Deeper Than Expected
A previous owner installed carbon fiber paddle shifter extensions on my '15 991.1 GT3; not a mod I would’ve done myself, but the look wasn’t bad. The bigger issue? The extensions blocked the view of both outermost gauges in the cluster. While I can display oil pressure/temp and water temp on the MFD, a quick glance at the analog gauges on track is far faster for me and more intuitive than scanning digital readouts.
Even worse, the paddles felt vague with no tactile feedback. Having owned other 991s, I suspected the extensions had put extra stress on the pivot mechanism, accelerating wear resulting in the sloppy [no] feel.
A quick eBay search turned up a used set of used OEM shifters. My original plan was to simply swap the paddle arms but that was before I learned what was wrong with my set. Once removed and the pivot shafts pulled, the issue was immediately clear: the spring-loaded detent plungers on both sides were broken. (Side note: interesting to see that the shifter sensors are actually small optical horseshoe sensors.)
At that point, I abandoned the parts-swap idea, and, instead, took apart the eBay paddles, cleaned them, and installed them as-is. Problem solved—clean clicks and normal shifts.
It is worth noting that it is a pain it is to access the paddles. To gain access to them, you have to remove the silver bezel on the front of the wheel. That means carefully prying it away using several plastic trim tools. It’s slow going, but it works. Once off, you’ll find the paddles held in place by two small 7mm nuts on studs.
As a proud boomer, I couldn’t resist supergluing the broken detent plungers back together. I was careful not to get glue on the outside of the part, but even though I wouldn’t reuse any of those parts, I have to admit: once “repaired,” the original OEM paddles actually have a noticeably more pronounced click than the eBay replacements. Maybe the spring is stiffer, or the detent profile was different. Either way, I’m not pulling the wheel again to swap parts and find out.
Hope that helps someone out there...
Hank
Old Aug 3, 2025 | 08:12 PM
skunkfoo's Avatar
skunkfoo
2nd Gear
Hank
I have this same exact issue, where did u pry the silver cover? and what was the fix in the end how did the parts go together?
Old Aug 3, 2025 | 09:49 PM
Hank Cohn's Avatar
Hank Cohn
I’ve attached a photo (borrowed from eBay) showing where to pry the silver bezel. You’ll need plastic trim tools, and ideally a second person to help. One person creates space between the wheel and bezel, the other inserts the tools. The bezel is held in by T-shaped legs with light adhesive, and lifts off evenly once all three spokes are loosened. Be careful—you're working against the Alcantara wheel. The paddles are plugged into the center bezel. Be careful to unplug those when lifting the bezel out of the wheel hub.
Once off, the paddle assemblies are secured with two 7mm nuts. Once the nuts/studs are removed you need a very small TORX bit to remove 3 screws holding the assembly together. Thankfully there is nothing that might fly out when disassembling. In my case, both detent plungers were broken, which explained the vague feel. Porsche doesn’t appear to sell just that part or even the paddle assemblies, and many eBay/other listings (claiming 2013–2019 fitment) are really for 2017–2019 cars, not compatible with the 991.1.
I bought a used set on eBay. They felt gritty, so I disassembled and cleaned them in warm soapy water, avoiding getting the small optical sensor or harness wire wet. I applied a light grease in the detent channel which may turn out to be mistake as it may attract dust over time. As a side note, 2011–2013 Panamera paddles look identical.
Thanks,
Hank
Old Aug 6, 2025 | 12:10 PM
TET GT3's Avatar
TET GT3
Good work. Removing the airbag first can be tough, and in my experience even tougher putting it back properly. The silver trim can also be difficult to remove without damaging/scratching anything.
I also had a cracked plunger and no click when upshifting, which I fixed with a repaired plunger.
Removed Torx screws and pushed out hinge pin to disassemble shifter.
Found the problem! Plastic spring plunger broken.
Old Aug 6, 2025 | 03:20 PM
skunkfoo's Avatar
skunkfoo
2nd Gear
Great video for trim removal "
Porsche 911 GT Sport Steering Wheel Disassembly by Craft Customs"
Old Apr 22, 2026 | 11:09 PM
Paul in San Jose's Avatar
Paul in San Jose
I drove on some rough roads outside of Death Valley taking the scenic route to Spring Mountain racetrack, and found the downshift paddle didn't work when I arrived. The paddle feel is still OK, however, so I'm wondering if a connection might have come loose. I removed the steering wheel at the track, but when I discovered the trim was glued in place I didn't dare go further and put everything back together. Can anyone who has had everything apart comment on whether there is a likely fault point for this symptom? Or could the fault even be downstream of the steering wheel, in which case I might want to verify this before completely disassembling the wheel.
Finally, anyone know the torque for the triple square bolt, and does everyone agree you don't have to re-glue the trim when reassembling?
Thanks!
