Engine Control Fault/Fuel injector
I have a new GTS 4.0 that threw an Engine Control Fault code at 300 miles. OBD reader showed cylinder 1 misfire. Dealer confirmed the same and after 2 days of diagnostics say the car needs 2 new fuel injectors!? I haven't seen much in the threads about this. Anyone experience similar issues? Did replacement injectors fix it? Just had a Q7 lemon buyback 6 months ago and I'm already having panic attacks.
I have found that with Porsche's and especially the newer ones, if you just clear the code it never comes back.
Is the car missing and running poorly or did the check engine light just come on for seemingly no reason?
Regardless, it's under warranty, there's a code, the dealer has an opportunity to get paid by Porsche.
