Wheel and brake upgrade
I have put on 997 Turbo rotors rear and back with a conversion bolts. The Turbo has also been converted to Rwd
I would like to upgrade at least my front calipers to something. Is there any after market calipers or is the best option to get 996 Gt3 front calipers. I am looking not to spend a whole lot the with replacing existing rotors and pads but I assume the pads would have to be replaced with 996 gt3 part numbers. For rear does the 996 turbo front calipers work on the rear or people just leave it as is?
My OZ 18x12 et51 wheel cracked so I am looking for a replacement. Is is possible to use 18x9 in front and a 19x11 is rear. I am running 235/40/18 315/30/18 but would like to try 235/40/18 305/30/19
The other possibility is to try and get something that look similar Apex SM-10 18x11 et45 and 235/40/18 and 305/35R18
The OEM brakes are generally more than sufficient even for cars that see track time, especially with 997 rotors and good pads. Since you already spent the money to convert to 997 rotors, the best use of money would be some very good brake pads.
As for the wheels, you can do the 18/19" combo, but you'll want your tire diameter difference front to rear to be less than around 5% (double check me on that number) or the ABS will freak out.
I mostly track the car. I also have a 2018 718 GTS and it brakes are way better then the Turbo. If I had better brakes I could brake later which would improve lap times.
Just checking the price difference from a 305/35R18 305/30R19 and the 19's are a huge price difference. Guess I am staying with the search for a 18x11 wheel
You're at odds here, you want a budget solution but want bigger brakes than the only budget solution you've already done. At this point you have to spend more money, the next step is what you've said, 996 GT3 front calipers. That's what I run, with the 350mm rear discs and have no issues with track performance. I also run a dedicated set of track brake pads...
Not sure about the 997 spare, my 996 spare will not fit over my calipers. It is in the frunk for crash safety only. If the 997 spare does fit I would like to know as I would like to get one.
vtec_ (10-02-2024)
We have plenty of light weight wheel options that could work for your application. Let us know if you have any questions or need help replacing that cracked wheel!
Corsa Forged // Corsa Forged LLC 🇺🇸
Fully Bespoke Performance Forged Wheels
Follow us on Instagram: @Corsawheels / Facebook @Corsa Forged
Sales: Corsaforged@gmail.com // +813.449.0349
