JCR Inconel 200 cell sport cats 992 Turbo and 3.0 Base S GTS
For SaleEngine - Exhaust
JCR Inconel 200 cell sport cats. Great sound upgrade and a bump in HP/TQ very simple install can be done with car on the ground takes about 35-40 mins start to finish. Only used for 480 miles no CEL, was saving for a friend with a Dakar but he went full catless. Paid $5k all in asking $2850 shipped to lower 48 states. PayPal accepted and local pickup in Santa Barbara welcome.
The latest turbo charged models from Porsche are formidable in stock form however there is always room for improvements to be made, especially in the exhaust system. Our direct replacement exhaust components not only save weight and improve sound they also deliver solid performance gains without compromise in a direct replacement part with perfect fit.
Light Weight
Through the use of light weight materials and clever design we have managed to reduce the overall weight of the factory 992 Turbo exhaust components. Removing weight full stop carries great benefits in any performance vehicle however the gains are exaggerated on this platform, reducing the rear biased weight distribution helps to improve overall balance and handling.
Direct Replacement
All of the JCR 992 Carrera / Turbo / Turbo S exhaust components are direct replacement for their OEM equivalents with guaranteed fit every time. No requirement for any further work during install beyond removing the OEM part and replacing with its JCR equivalent and any supplied hardware.
HJS 200 CEL Cat
The JCR Inconel Race Cat removed the factory dummy OPF matrix and restrictive factory cat and replaces them with a high flow HJS 200 Cel cat. Flow is therefore greatly increased and improved performance comes as a result. For cars with no OPF monitoring our Race Cats in most cases will not cause any CEL and do not require any tuning.
In certain instances it's still possible for a CEL to occur. This tends to be if the car has poor fuel quality in the tank or excess load is applied when the engine and exhaust system is not up to full operating temperature.
Power Increase
Every component of the JCR Titanium Exhaust line is guaranteed to improve HP & TQ with varying results dependant on the combination of parts. Our most extreme free flowing system will see gains in the mid 30HP&TQ with the stock ECU tune. Also expect great improvements in overall engine response, transient throttle response and boost building earlier in the RPM range.
Key Features
- 100% Inconel 625 Construction
- HJS 200 Cel Race Cat
- Direct Replacement Parts
- -6.10kg Weight Reduction vs OEM Cat Sections
- Improved Sound Quality
- 20-25HP & 30-35TQ Increase
- 992 CARRERA
- 992 CARRERA S
- 992 CARRERA GTS
- 992 TURBO
- 992 TURBO S
- 992 SPORT CLASSIC
