The suspension overhaul begins
After two years of saving money (it wasn't enough), and squirreling away parts, it's finally time to get to work on the 993 suspension overhaul.
First order of business is sending the calipers off to PMB for a rebuild. I hope to have them back by the time the rest of the work is complete.
All suspension components will be replaced or refurbished. The majority of the suspension will be Elephant Racing stock with a few bits from Tarett Engineering. Bushings will be sport rubber, with several select location monoballs. Subframe bushings and the transmission mount will be sport rubber. Coil overs are Tractive (non electronic). Inner and outer tie rod ends with bump steer will be installed. RS roll bars and drop links will go on.
A Numeric short shifter is also going in, and RS side skirts will be installed.
I was to do the bulk of the work myself, however health issues have changed my plans (in more ways than one). Now a local indy will do the install and I will help as I can. We hope to be complete by the end of next week.
The following 5 users liked this post by SpeedyC2:
996scott (09-25-2024),
dalves11 (09-25-2024),
Kein_Ersatz (09-25-2024),
MrRoboto (09-24-2024),
orangecurry (09-24-2024)
Wondering what your thought process was in landing on Tractive, and not getting the electronically adjustable dampers (i'm assuming that's what non-electric means)
I bought the Tractive coil overs about 1-1/2 years ago from TPC Racing in Maryland. I had a bit of history with TPC from when I was doing track events with my Cayman at VIR. They were moving their shop and posted here about a sale they were having so as not to have to move inventory. They had a few sets of both analog and electronically adjustable units and were offering a very good sale price. By the time I contacted Tom at TPC to ask about them, there was only one of the analog sets remaining. I figured I really didn't need the cost and complexity of the adjustable units (though I bet they are very nice), so I decided to buy the analog coil overs based on Tom's feedback on their quality.
MrRoboto (09-25-2024)
Subscribed! Thanks for taking the time to document your upgrade journey. Hope you health allows you to at least enjoy the "ride".
Plastics and rubbers on 25 year old cars will need addressing, had both shifter tension rods "fail" (drop off) on my two 993s within weeks of each other. :-P
SpeedyC2 (Yesterday)
Good question.
Good luck with your install.
SpeedyC2 (09-25-2024)
Parts pictures ****:
Parts table
The other parts table
Elephant drop links
Tarett tie rods
Tarett toe links
Front coil overs
Rear coil overs
Parts table
Elephant drop links
Tarett tie rods
Tarett toe links
Front coil overs
Rear coil overs
I was able to get one of the two electronically adjustable units during that sale. I think @fnckr got the other set. From what I've gathered, @nk993 also installed a slightly different set and with different controller (Nine Excellence). I just finished up my install and total overall of suspension. Probably owe back to the community a thread.
Hope the best for your health. That’s everything!
The following 2 users liked this post by gbgastowers:
orangecurry (Yesterday),
Well, I haven't completely finished it yet. But I did drive it to the alignment shop (good but some funny action, expected) and from the alignment shop (felt great). Surprised at how much an alignment makes a difference. I am having an issue getting power through the controller so it's currently at full stiff, so didn't push it since hitting a bump hurts everything. Lots more to evaluate. I know 993 are sensitive to alignment, but it felt really good. Made fully stiff feel like I could live with it.
I love those Tarrett rear toe-links. If you didn't get the fixed washers for them you need to - they are essential.
These are the reasons why they are great:
1. Finer adjustment vs the eccentric washer
2. Once they are set they are set - no need to mark them or readjust them when you take the suspension apart and put it back together
3. The two piece design is way better than the one-piece OEM design because you can separate them at the wheel-end of the link and leave them bolted at the engine end, so you never again need to deal with trying to squirrel those bolts around the heat-exchanger part of the exhaust. Makes dropping the whole crossbar + sway bar assembly super easy.
Note that the bolts that come with the fixed washers are a bit too long and will need to be cut down!
Thank you for this information!
Fixed washers are on the way now...
Here's a pic of what I was talking about - the whole cross bar and sway-bar assembly removed as one piece, and it can be put back with no loss of adjustment.
The fixed washers and bolts (highlighted) replace the the eccentrics.
Very helpful! Thank you again.
