Stiff brake pedal after sitting for 3 weeks?
We recently returned from a three week trip. I placed the Cayenne on the CTEK so that the LiPOS battery wouldn't be fubar'd. First thing I noticed is that the car was sitting much lower than normal on all 4 corners. Perhaps I have a leak somewhere in the suspension system? The second thing I noticed is that the brake pedal was stiff and almost immovable. I had to really stomp down hard on it to get it to trigger the interlock and allow me to start the car. Anyone else experience these problems with a car that has been sitting around?
I’ve had cars where the bake booster vacuum reservoir leaks out completely if the car has been siting for a week or so. Rock hard pedal until the engine is started. Most cars don’t do this.
Mine does this occasionally after a week sitting. I notice it because I press normally on the pedal and turn the starter and nothing happens. At that point I realize the brake pedal needed more force (quite a bit actually), then the car starts and everything is normal.
Hmmmmm......could it be "normal" for Cayennes then? You also have a GTS yes?
I wouldn't worry about the brakes. It often happens after a long standstill that the servo loses pressure. This is normal.
I would be more concerned about the loss of pressure in the suspension system. This could mean a leak in the air spring system.
matthewr87 (09-20-2024)
I had this exact same problem with my 2021 Audi SQ5.
The problem was addressed and rectified via warranty per the Audi TSB attached below.
The following 2 users liked this post by Ironman88:
matthewr87 (09-20-2024),
Schnave (09-20-2024)
I had this phenomenon in several of my previous Audi Q7 and Q8. Often after a long standstill the brake pedal would become hard. After starting the engine this phenomenon disappeared immediately. It is simply normal that the servo is not able to maintain pressure during a long period of non-use. I have never worried about it.
However, all my 4 previous cars that had air suspension never lowered themselves even after a long period of standstill.
