Cayenne 2019 Drivers side front lights not working
Hi guys, was wondering if anyone could help with providing the location and Ideally images of the headlight fuse location on a RHD 2019 Porsche Cayenne. Have looked online and the fuses shown are not the correct ones for the headlights. The right sight headlight and DRL are both not working. Have swapped the DRL over to test and definitely a power supply issue. Thanks in advance.
Here’s what page 124 of my 2019 Owner’s Manual says (full PDF manual attached).
I was surprised to see two fuses for the Right Headlight Electronics: C9 and D15.
There are three fuse boxes in the Cayenne: Dashboard, Footwell, and Luggage Compartment. The headlight fuses are located in the left footwell fuse box.
My left-hand drive fuses are similar. I labeled your fuse rows and numbers using the same logic: A - E top to bottom and 1 - 12 or 13 left to right.
I don’t have a photo of right-hand drive. My left-hand drive has vertical rows of fuses. Yours should be similar, except your rows should be horizontal. Each row has a pink plastic cover. It just pops off with gentle prying.
Note that some rows contain 15 or 16 fuses. For example, In row A, below, fuses 14, 15, and 16 are oriented perpendicular to the rest of the fuses as outlined with dotted lines below.
The following 3 users liked this post by Schnave:
