Panamera Shaking at High Speeds
2011 Panamera S.
Around 5-6 weeks ago, I had gotten a major service done and replaced the stock motor mounts (which used to shake crazy) with a pair of Lemforder motor mounts. So far they're keeping up with minimal vibration except when idling, you can feel a teeny tiny bit if you're in the driver chair. extremely minimal and barely noticeable.. I thought that was the USUAL since when I started driving with the car, they used to shake crazy.
All was fine and dandy until I started dailying my car again for University (around late August). First week was fine, and then 2nd week I began noticing vibrations at around 105/110km/h .. (60-65mph) and above.
The whole car shakes at this speed, you can feel it in the chair and even someone sitting in the passenger seat can feel it.
So I thought, it's probably the alignment and tires balancing. Took the car for an inspection, and they told us there was a leak in the steering box and the rubbers.
Great.
We got it fixed just today (as of the time of posting this) and did the wheel balance and the alignment.
What's crazy? Didn't fix anything. The steering wheel is EXTREMELY SMOOTH now feels like literal butter, but the car still shakes at the previously mentioned speed.
Perhaps the motor mounts have something to do with it? Maybe the person that installed them left them a bit loose? Just a wild guess.. since that's the same person that caused my steering box leak by improperly changing the power steering oil.
When revving the car when stationary, the car DOES NOT shake, even at fairly high RPMs.
The car cruising in 7th gear at around 90km/h (55mph) does NOT shake either. No shaking in any gears either.. PDK seems to be in great condition despite not being serviced yet.
Tomorrow I'm going to try it on the highway, and get more information on certain speeds and whether the vibration increases.. speed limit is capped at 140km/h (86mph) on the highway btw lol
Great.
My leaking motor mount caused a slight vibration, but I could feel it when going slow too. Shaking at certain speeds is usually caused by out of balance tires or bent wheels. When I had a mustang with drag radials that were tough to balance, I found a lot of shops need their machine calibrated and/or just get it "close enough." Worn out tires are also difficult to balance perfectly, maybe impossible if unevenly worn. If the steering wheel is smooth, that rules out the front wheels. I would have the rear wheels checked again.
Regarding the motor mounts there is still a fair bit of vibration even when the car is idle, you can feel it while in the driver chair.
I just got home a bit ago, and was experimenting a bit with the car after the alignment and wheels balancing.
At speeds below 105km/h, the car doesn't shake and drives as usual. Steering wheel doesn't shake or anything, smooth as butter.
Above that speed, the car starts shaking and the steering wheel vibrates a bit..
Might get the rear wheels checked next weekend hopefully, I'm thinking maybe the rear-left wheel since I actually hit a curb while driving back home late at night lol
Symptoms; speed dependent vibrations, primarily driveline. Could be felt in steering (especially if AWD). If wheels are true and balanced, I'd check there as well. The rubber that holds the bearing wears out and allows the driveshaft to oscillate/vibrate. JXB makes a two piece replacement that can be installed without driveshaft removal.
At those speeds, vibration/shaking can be felt throughout the car, in the front seats and back seats.
Will be taking a look ASAP.
On the JXB carrier bushings...they are only listed for a Cayenne. Will they work on a Panamera too?
Known issue with Panamera 4, Turbo, GTS. See the following:https://rennlist.com/forums/panamera...hat-to-do.html
https://rennlist.com/forums/panamera...-55-60mph.html
