A/C stopped working after R/R evaporator coil
Old 08-30-2024, 10:25 PM
kamaro
kamaro's Avatar
Default A/C stopped working after R/R evaporator coil
My A/C was working fine except for a leaky evaporator so I spent the past two weeks taking apart half of the car just to reach and replace it, everything went smooth and straight forward (just time consuming), now I got the evaporator box back and decided to refill the refrigerant and just connect the climate controller and the A/C switch panel to test the A/C before getting everything buttoned up, it seems there is no power going to the climate control at all (tried all the positions), and the A/C push switch is dead also. I checked the blower relay and fuses no 3,6, and 17 and all were OK. I put 12v directly to the blower and its working fine. the A/C push switch has no power to it. The blower relay has power going to #30 terminal. I checked the blower connector going to the climate control and it has no power going to it. can someone help me before losing my sanity? .. I spent at least 10 hours today just trying to figure out whats happening!
Old Today, 02:35 AM
kamaro
kamaro's Avatar
Problem fixed. I thought the blower relay was the "X" one, after checking the schematic diagram I found it was "VIII" .. replaced it and now all working as it should.
Quick Reply: A/C stopped working after R/R evaporator coil
