Who can rebuild a front differential these days?
I have a front differential on my '02 that is making more and more noise. It has 62K miles on it. First thought it was tire noise, with the tires being what they are, but to my ears the noise was different. Then I was convincing myself it was a wheel bearing. So when I took it in to my favorite Indy shop, they put it on the rack and spun the wheels under power and found the noise is coming from the diff. They say it might be a bad bearing, or worse. That was at the end of the day, so we didn't get any further than that. They want to try changing the fluid first to see if that remedies anything, since we don't have any record of it being changed (and it was nasty looking).
Being paranoid, I started sniffing around the internet to see what a used diff would cost at places like DC Auto and LA Dismantlers. I've also seen conversations about people having theirs rebuilt. At this point though, I don't know what components are bad. Anyone have a similar experience with it needing repair, and what the complications and remedies were?
Thanks much,
Steve
Thanks much,
Steve
diverzeusy (08-17-2024)
When the one on this car went this kit was installed and was like new again…
https://www.speeddensitymotorsports....000-2013-awd-1
ebay and various dismantlers have them oretty available if you need to buy a used one and they are a hair less than the repair kit so seems like you have options
The following 2 users liked this post by Scrh1:
diverzeusy (08-17-2024),
sullivs (08-19-2024)
In 2009 Adam699 did the bearings replacement on the front differential and post it 6speed...Unfortunately the pictures are not there anymore but here's the link in case it can be useful....https://www.6speedonline.com/forums/996-turbo-gt2/192257-diy-fix-your-own-996tt-front-differential.html
I save all the piture if you want them....
sullivs (08-16-2024)
CMS can do them as well.
The following 2 users liked this post by jpflip:
blockhed (08-18-2024),
TheDeckMan (08-22-2024)
The following 3 users liked this post by jpflip:
Tiptronic 996 to GT2 conversion
Has anyone got any input and information on my 996 Turbo - Tiptronic - 2wd conversion?
My main concern being, does the gearbox and transfer box sort it's self out when the prop shafts is removed?
I know the prop shafts is removed at some shops for for dyno runs, so I'm guessing the tip is OK?
I ran my Tiptronic car with the front diff removed and had no problem at all. The Tiptronic has an open differential so rear wheelspin might be more likely.
Thanks theprf 👍
Do you know if a LSD is available for the Tiptronic?
Ironically enough. They are in AZ. Ask for Roger.
https://californiamotorsports.net/
https://rennlist.com/forums/996-turb...-required.html
When I jack the front wheels up in park, the front wheels spin freely.
I am guessing at this point its just dead weight?
Doesn't the PSM more or less act like a rear diff?
