Part number for the rubber hose that comes out of the throttle body?
Are you asking about the one that connects the filter air box to the throttle body?
Auto Atlanta lists 3 different part numbers, due to difference in model years.
http://www.autoatlanta.com/porsche-p...section=107-00
You could also replace it with an aftermarket silicone tube. This design bypasses the Helmholtz resonator and amplifies the growl of the induction system.
https://flat6motorsports.com/collect...intake-kit-996
Sorry, the one that comes out from the yellow part on the throttle body and goes towards the coolant tank kinda. It's also held up by a bracket thats also bolted down with the throttle body (top right hole)
Can you share a photograph? I’m having trouble trying to remember the yellow part of the throttle body.
