Modified 1979 Porsche 911 SC
1979 Porsche 911
  • 1979 Porsche 911 - Modified 1979 Porsche 911 SC - Used - VIN 9119200514 - 219,800 Miles - 6 cyl - 2WD - Manual - Coupe - Red - Kingsport, TN 37663, United States
rsalison is offline
    $69,900
  • Location Kingsport, TN, 37663, USA
  • VIN 9119200514
  • Mileage 219,800
  • Exterior Color Red
This 1979 Porsche 911 SC has been transformed into a stunning lightweight 964 RS tribute.  This Porsche is equipped with a 3.0-liter flat-6 engine, believed to be original to the chassis, which has undergone a top-end rebuild approximately 25,000 miles ago.  This legendary engine is paired with a 915 5-speed transmission, which is believed to have been replaced with a period-correct used unit.
While the odometer displays approximately 219,800 miles, it's noted that, like most older Porsches, its exact true mileage is unknown.  The speedometer has been upgraded to a 170MPH unit and has been rebuilt with a replacement odometer cog, eliminating issues from the deteriorating original components.  Based on the thorough service history provided with this car, the mileage approximation is believed to be fairly accurate.
The vehicle is currently presented in an older respray in a shade reminiscent of Guards Red (original color was light blue metallic), over a standard black interior.  The paint, while not flawless, still shows well.  The driver’s side quarter panel was touched up at some point in the past, and was notably completed to a lesser quality than the previous full body repaint.  The body retains all original Porsche steel and is exceptionally straight and rust free with only two minor areas of corrosion to be noted - one at the base of the windshield and the second inside the drivers door jamb.  The undercarriage was undercoated in period, so the underside of the vehicle remains incredibly solid and rust free.
This Porsche comes with an extensive binder filled with mostly complete service records and history dating to the mid-80s, providing buyers with an insight into this car’s pedigree and history of thorough care, maintenance, and restoration.  This PCA member-owned, modified 1979 Porsche 911 SC is now offered with a clean and clear Tennessee title.
Notable cosmetic and interior enhancements include:
-Cosmetic 964 conversion: fiberglass front bumper, fiberglass rear bumper, fiberglass side skirts, aero mirrors, 964 tail lights
-H4 headlight conversion
-Custom offset Italian Millemiglia Cup 3 “turbo twists” wrapped in a staggered set of Michelin Pilot Sport A/S 3+ tires
-Stainless steel half roll cage with rear seat delete
-Element fire extinguisher mounted in an Element roll bar mount
-Rennline RS-inspired lightweight door cards with 911R style door straps
-Rennline aluminum floorboards
-Rennline HVAC cover
-Rennline aluminum pedal set and dead pedal
-Rennline lightweight mechanical hood and decklid struts
-MOMO Prototipo steering wheel
-MOMO collapsible steering wheel hub
-MOMO Anatomico shift ****
-Red seatbelts
-Embroidered floor mats
-Main fuse block and engine fuse block replaced with ATM style fuse panel and headlight relay kit
-Optima battery in a custom battery mount with new terminals and ground cable
-Al Kosmal’s XFaktory front and rear lightweight grilles
-VDO Bluetooth stereo with upgraded speakers
-Backdated heating system
-Open-ended steel lug nut kit
Notable mechanical upgrades include:
-Updated hydraulic timing chain tensioners
-Airbox pop-off valve
-Wevo semi-solid engine and transmission mounts
-Wevo precision shift joint
-Wevo classic shifter
-Turbo lower valve covers
-SSI stainless heat exchangers
-Stainless aftermarket 2-1 muffler
-Lightweight high-torque starter
-Bilstein performance rear shocks
-Front strut brace
-Turbo tie rods
-Rennline sealed rear monoballs with Wevo EZ pin kit
-All new rubber fuel lines
Within the last 15,000 miles, key maintenance and service items addressed include:
-Full brake rebuild with Hawk pads, drilled and slotted rotors, all four calipers rebuilt with new seals and refinished in a classic silver, stainless brake lines and Speed Bleeders on all four calipers, new master cylinder, and DOT 4 brake fluid
-Refreshed fuel system with a new fuel pump, fuel check valve, fuel accumulator, fuel filter, rubber fuel lines, and a fuel injector cleaning and gasket replacement
-Full engine tune-up with spark plugs, correct Beru spark plug wires, distributor cap, distributor rotor, and new vacuum advance line
-Four wheel alignment
-New ignition switch
-All new power window switches
-Rebuilt door strikers
-Rebuilt and refinished pedal set
-All shifter bushings replaced
-New fresh air blower motor
-New fuel cap
-Valve adjustment
-New timing chain guides
-New axle half shafts and CV joints
-New rear wheel bearings
-Adjusted and re-packed front wheel bearings
-Engine sump plate replaced
In preparation for its next owner, this Porsche has received a full maintenance checkup, including a full interior and exterior detail, engine oil change with Penn Grade oil, gearbox fluid change with Swepco 201, a new air filter, new fan belt, replaced shift shaft seal, shifter adjustment, front bumper repaint, and new front turn signal assemblies.
For full disclosure, known flaws include:
-Typical air cooled oil leaks
-Aging plastic on the 964 style tail lights and center bar
-Miscellaneous paint flaws and rock chips, common with an older repaint and driver’s car
-Previous touch-up paint work done to the driver’s quarter panel does not show as well as the rest of the car.  This area includes more texture in the paint, some areas where the paint has released from the surface creating a “bubble”, and a paint flake on the fender edge
A paint-matched 964 RS 3.8 style rear wing is included (but not installed) with the vehicle.  An original full tool kit, jack, and spare tire are also included (but not installed), if the buyer desires.
With its sports minded upgrades and thorough mechanical rejuvenation, this Porsche delivers an exceptional driving experience, worry-free ownership experience, and is prepared for any roadtrips or rallies its new owner may desire.  This is a great opportunity to get into a well-sorted, driver’s 911.  Please feel free to reach out with any questions, specific photo requests, or to view the vehicle.
Old Today, 01:16 AM
rsalison
rsalison's Avatar
Here's a Google Drive Link that includes a cold start and walk around video.
