Procedure after airbag deployment?
Hey all --
Rebuilding a salvage 991.2: I've replaced the driver knee airbag and the steering wheel airbag, and had both front seatbelts rebuilt. Everything is installed and ready to go. I was reading I might need to clear the airbag module from the fault? I have access to PIWIS 3 so I'm assuming it can be done in there (can someone guide me to what screen this would be under/the procedure in general?) Is that it? I saw there are crash sensors in the front of the car, can those be reused? Not sure if they're a 1 time deal.
Basically, what do I need to do to not blow all the airbags when I reconnect the battery? Haha. Thanks!
991.2 TTS ... Front end damage -- driver side fender + bumper replaced, headlight, lower control arm, radiator, AC condenser... Decided to grab some new wheels while I was at it since 2 or 3 were lightly scratched and 1 was bent. Steering wheel airbag and driver knee airbags deployed and the seatbelts locked. Fairly easy fixes, but I haven't dealt with airbags on a 911 before, not sure if things were like other cars or if anything special needed to be done. Also never used piwis before but I'm sure it's similar to other software I've used previously. Waiting on a few minor parts to come in early next week but everything should be good to go by next weekend!
