My 2002 is finally coming home from the shop after new clutch, gearbox rebuild, LSD add & engine out service. Time to replace the outdated 19" wheels from the PO. Want to go to 18" that fill the arches without rolling or aggressive camber settings. Any suggestions?. Not interested in twists, or cast wheels. Car has been converted to 2wd and lowered on coilovers.
Need to know the original wheel sizes (including offset) to get started shopping.
Thanks!
Thanks!
I wouldn't run OEM sizes with the addition of an LSD on a RWD converted and lowered car. I'd start with GT2 sizing. You might want to rethink not rolling the rears to accomodate wider wheels and a lowered stance. If you drive aggressively in off camber situations there will be some rub if you don't make some minor adjustments fo wider wheels. Same with "settings" for a lowered car. The potential for premature tire wear always exists with "stock" alignment settings. Usually "toe" less so "camber". Everything is a "trade-off".
I believe these numbers are correct. Internet search yields:
I was looking at some SM 10's ( again ) by APEX which are a decent and comparable alternative to my old OZ and remembered also to mention one other combination I have run many years ago that sat perfectly with a ( then ) 1" drop. 7 X 15 spacers with stock 996 TT wheel offsets.
You might also find this guide of possible combinations available helpful.
