Driving with the A/C on these cars is terrible..
It's surprising to me just how laggy my 2011 Cayman Base 6MT is when the A/C is on and it's hot/muggy out (less oxygen density air). You really have to giving the motor at bit more rpm leaving the line and better manage the 1-2 and 2-3 shifts to make it smooth. The A/C works very well, but definitely has a drag on the high strung 2.9 motor. It reminds me of my old 1990 CRX Si with the A/C on in terms of the difference in the way the car drives. I only run the A/C in the Cayman when it's hot out and I have a passenger. This car was clearly designed to be driven with the A/C off and windows down. Different animal and drives so well like that. I would imagine the PDK drives quite a bit better with the A/C and may not be as noticeable.
Mfleahy (06-20-2024)
Not in MA anymore
On my '05 base Boxster I dont noticed any difference with the AC on or not.
The following 2 users liked this post by Matt(inMA):
Carfan1 (06-22-2024),
indiovravo (07-21-2024)
Automatic or 6MT? Do you drive with the A/C on all the time? If I put my Cayman into "auto", the A/C is on almost all the time. With the A/C on in my Cayman, it feels like the flywheel is twice as heavy. It makes sense though as the compressor is pretty big and puts a lot of drag on the accessories. 90+ and muggy doesn't help things. The effect isn't remotely as noticeable if it's 70 and I'm running the A/C for defrosting purposes.
Guys, everything in his Cayman is not working right. Nobody knows why!
scootr (07-02-2024)
Cheers,
Julian
Anyway, I don't know if you actually have an issue or not, but regardless you may want to try a Sprint Booster. I'm pretty sure the 987.2 nerfs the throttle when the clutch is down, and if you're used to driving a traditional mechanical-linkage throttle (like I am) it can at times be annoyingly challenging to get a smooth pull-away or rev match shifts in my experience.
The Sprint Booster remaps the throttle to make it adjustably more responsive. It doesn't add any power or make the car any faster, but it's a night-and-day difference in drivability. That may help minimize the impact of the additional compressor drag if that is in fact what you're feeling.
Do a search: pretty much everyone on here who's tried one will swear by it.
Ric In RVA (06-20-2024)
Pretty much
I'm probably more just in tune with my cars than others. I drive this car all the time, in all conditions and temps except for snow unless absolutely necessary. Most owners on this site seem to drive them a couple thousand miles a year and on weekends.
I'm not worried nor do I think there's an issue. The A/C is strong, the temps very well managed, idle is fine, no power band hiccups. the A/C shuts off with full throttle, etc. it's just surprising how much more lag there is when leaving the line and on shifts. It can make me feel like a manual driving amateur when leaving the line and on the 1-2 or 2-3 shifts unless I rev a bit higher as the A/C accessory drag drops the rpms much faster. Those with 3.2-3.4 motors might not notice much difference given the added displacement. My guess is Porsche does a mild throttle recalibration when the A/C is on and perhaps it's at odds with Sport mode plus the Sprint Booster being on (Sport setting #2). I know BMW modifies the throttle sensitivity when the A/C is on to account for accessory drag. Again, I don't think someone with a Tiptronic or PDK will notice much difference.
![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
eyedoc (06-23-2024)
I'll be curious to hear your thoughts since you live in the same area. I don't notice much difference when it's cooler out and it's in Auto as the A/C doesn't seem to cycle much or as aggressively. 90+ and muggy though? Way different driving experience for me.
eyedoc (06-23-2024)
I'm not alone. Some of these 986 owners certainly can feel the difference I'm describing and it's not an old thread either: https://986forum.com/forums/boxster-...s-power-c.html
Tonight I'll turn the Sprint Booster off and see if it impacts anything.
I have an 05 BS and previously had an 86 CRX Si. If turning on the AC in your Cayman reminds you of an old CRX, I’d say something is wrong with your car.
2008 Cayman S, 6 MT.
I can’t detect a difference with the AC on. Except for the cold air coming into the cabin. A godsend in Australia.
(I’m enjoying winter - no AC and the window down - Wind in the hair and the Flat 6 symphony.)
