(7) Used 19" Forgeline GS1R Wheels for 16'+ Porsche Cayman GT4 (may fit other models, you will be responsible for verifying, specs are listed)
These have been used as track wheels their entire life. Overall in good shape but they are track wheels. Keep that in mind.
The set of (4) that have tires on them feature Bridgestone Potenza RE71r tires. They are date coded 2019. They have tread life remaining on them. Have had quite a few heat cycles. Probably not the quickest tire you can run at this point but they do have some track time left in them.
(2) 19x9" +50mm with 245/40/19 RE71r - Satin Black, No Center Cap, Knurled Bead - TPMS Installed
(2) 19x10.5" +44mm with 285/35/19 RE71r - Satin Black No Center Cap, Knurled Bead - TPMS Installed - This set with Tires has been Sold
There are 3 more wheels that have no tires on them. Great to mount extra tires to have in the trailer at the track.
(2) 19x9" +50mm - Satin Black, No Center Cap, Knurled Bead - TPMS
(1) 19x10.5" +44mm - Satin Black, No Center Cap, Knurled Bead - TPMS These are still available
