992 Carrera S - Exhaust Advice
Based on my searches the lackluster sound of the PSE is a common issue. I've done a deep dive on Flat 6 Motorsports and watched all of their videos on all the exhaust systems but have a hard time getting a good sense on how the systems differ with the audio.
This past weekend, I heard a full Soul valveless exhaust system with high-flow cats in person and was blown away, it sounds amazing. To add to that, my dealership is now offering tuning with GIAC (warranty stays intact) as well as Tubi Style exhaust purchase and install. I do have some reservations and don't want to jump straight to going with a full Soul system if I may be satisfied along the way. My current thoughts are to try the cargraphic valve controller first, and if that doesn't scratch my itch to then move up to Soul high-flow cats, then add the valved exhaust if it's still not enough. I wanted to see if anybody can share their advice on what route they took to get their exhaust sound to a place they were happy with. If any of you have any good audio/videos to share as well that would be helpful.
Cargraphic first. Then go from there. Sport cats for volume. Catback for tone.
Sport cats likely require tune to avoid CEL.
Skip cargraphic and get M Eng tune if you’re considering a tune anyway.
Dealer doesn’t decide warranty and can’t guarantee you anything.
The following 3 users liked this post by jhenson29:
I have a GTS, but I started with cargraphic and it wasn't enough for me. I went with iPE stainless after watching all the Flat6 videos (still on factory cats). It does sound much better with a whole lot more turbo sounds. Probably will end up with sport cats eventually too, I like loud sports cars and it's my weekend car. Here's a sound clip on cold start with valves full open.
Galvano (06-09-2024)
There is no tune where your warranty from PCNA stays intact. It’s explicitly written in the manual that even if the product is installed or sold by an authorized dealer, it doesn’t matter if it’s not from Porsche.
Chris Connor (06-07-2024)
Received 2,648 Likes
Quite correct! Also, if the "Tune" changes the Emissions Check Digit in the Computer, and even when returned to the original programing this isn't restored correctly . . . . . . not only will the dealer and manufacturer (Porsche in this case) know it's been messed with. In some states, the car won't pass the periodic State SMOG Check test needed to renew the vehicle registration.
Here are the steps and order I would follow and stop when you are pleased with the exhaust:
1..) Cargraphic valve controller and assess
2.) Valved or valveless catback exhaust system (stainless, titanium or inconel) and reassess. Sell valve controller if valveless
3.) Sport cats
4.) Tune
This allows you to install 1 & 2 and fully assess before installing 3 & 4 with potential warranty issues discussed above. You can also enjoy 1 & 2 until warranty expires and warranty issue becomes a moot point. If you have already decided on a tune, however, go for all of it and do not need controller.
3.) Sport cats
4.) Tune
The following 2 users liked this post by Fullyield:
drcollie (06-03-2024),
Vicbastige (06-03-2024)
Received 4,134 Likes
Do your mods in stages is best, as you can see what each one does. If you do everything at once, then don't like it - you're not sure which of those mods is causing the dislike. I learned that the hard way with a 2007 Aston Martin. Did everything all at once (Exhaust, Sport Cats) and the car was so loud it was undriveable on public roads, you could hear it half a mile away. Also, doing it in stages lets you check for the dreaded highway drone, some exhaust mods will result in that, others not so much.
The following 2 users liked this post by drcollie:
Fullyield (06-03-2024),
Master Deep (06-03-2024)
3.) Sport cats
4.) Tune
3.) Sport cats
4.) Tune
Further, any warranty denial would have to show that the modification itself caused the problem. A tune is risky. But exhaust systems are much less so.
https://rennlist.com/forums/992/1335...l#post19474075
There are 2 modes. Mode 1 is valves open, Mode 2 is OEM operation so if the Cargraphic is in mode 2 the PSE button will function as it currently does, in Mode 1 the valves are open all the time.
Thank you all for the great advice, it's very helpful. I like the idea of trying the mods on in stages so I'm definitely going to go that route. As far as warranty, the dealer did say specifically they deal with many vehicles with tunes on a daily basis and it has never resulted in a warranty denial. In the event that it did it would be related to the engine and/or transmission and GIAC (the tuner) has a warranty if there is a denial related to the tune. All that being said, not sure I want to put it all to the test. I will start with the Cargraphic and go from there.
Even if there is a problem, the only part of the warranty that will be affected is related to that part—e.g. they can’t deny warranty for a power window regulator for an engine mod. The rest of the warranty remains intact.
I'm not saying don't tune. I'm saying you have to be prepared for if the motor goes when the ECU has been flashed. Even M-Engineering doesn't speak in absolute that the tune is ironclad, undetectable.
good advice in this thread with order of mods. One reason to take it in stages is you may come to appreciate a car that sounds good but isn’t crazy loud…e.g. you may get to a point and decide it’s the sweet spot. My 992 is certainly a lot quieter than my 981S was (which had Soul sport cats/exhaust), but I’ve come to actually kind of like it as I don’t feel like an asshat every time I get on it, but it’s still loud enough to give me a good smile every time. FWIW, I settled on valves open 100%, Akra catback, stock cats, and cold start delete. I run valves closed as I leave the neighborhood, then open them as soon as I get on the main road. I’ll also close the valves on long hwy stretches where I’d prefer to listen to music rather than the exhaust. IMO this setup with valves closed sounds very OEM, and even with valves 100% open is what I’d describe as OEM+, not really offensive.
