What type of scanner
I have a base 17 Carrera and would like to change the boost gauge readout limit. I have a tune and but the gauge will only show 15psi max and I now the tunes boost is much higher than that. Is there a scanner that will change the boost gauge psi limit?
Thinkdiag magic.
$100.
I used it for the following, May have forgotten 1 or 2 other things.
Raised boost level reading to 23 psi, mine tops out at 21/22psi.
Water temps read real.
Turn signal blinks 5x vs 3x.
Tear drop function turned on for wipers.
Brake lights flash under moderate braking.
Auto start stop set to last used (off in my case).
$100.
IXLR8 (05-28-2024)
Impressive features for that low cost. But those who don't have an Android device tablet or cell phone will need to acquire one and thus add that to the cost.
Also, doesn't the ThinkDiag require an active connection to their database, e.g. via WiFi or cell phone to the internet? Where my house and garage and car are located, that's not likely to exist or when existing not a strong enough and reliable enough signal.
I bought a thinkdiag to do this and much more. Sadly I don’t have an android device my my brand new Thinkdiag has never been taken out of its packaging. Would love a good recommendation for a new, inexpensive android device that would work easily with it.
And have used it on my MB and BMW for maintenance needs, such as retracting thr parking brake when doing rear brakes on the BMW.
The OBD device links to your Android device when programming or using it. Not sure if it goes to the database in the mother ship.
I no longer use a Foxwell 510 that I had for simple maintenance on the BMW.
Definitely paid for itself and if you still need and Android device it will still pay for itself.
