NEW 992 GT3 PCCB Yellow Calipers - complete, never mounted!
For SaleBrakes
QTY 4 - Brand new never mounted 992 GT3 Yellow PCCB calipers in boxes - PNs are:
Front - 9GT.615.123A, 9GT.615.124A
Rear - 9GT.615.423A, 9GT615.424A
$3,900 plus $150. shipping in CONUS w/ payment via Paypal F&F. Also can pick up in El Cajon, CA 92020.
XLCMXI (05-11-2024)
not sure, but come down to Alpine and we will try them out!!
I'm pretty sure they will fit - you would. need to pair them with some surface transform rotors, or stock GT3 carbon rotors.
I've had several inquires as to fitment on various 992 generation cars - from the various posts here on the forum, it appears they will fit on nearly all 992 generation vehicles. There is a good write up here describing the retrofit w/ steel rotors:
https://rennlist.com/forums/992/1327...rsports-4.html
Go to post 48 for the detailed description and PNs for parts required for the retrofit.
https://rennlist.com/forums/992/1327...l#post18518046
bump
ttt
TTT
ttt
bump
Still available . . .
I’ve heard that these calipers and the steel (red ones) are essentially the same piston size etc. basically just color change.
But… I like the yellow calipers (compared to the red) to match the ohlins coilovers on the 991.1 gt3.
Is that the same you’ve heard to? Essentially I want to know is the 991.1 991.2 and 992 calipers all the same?
Actually, I don't know - but I have a set of red ones so I can compare. I believe that is correct, but I"m not certain. I don't have any 991 generation calipers, but I do have a set of 992 red calipers . . .
Yes let me know if it’s the same as the red ones you have. Hopefully others can chime in to see if the 992 PCCB yellow calipers are identical to the 991 Steel red calipers.
