958 Cayenne Turbo Hard 3-4 shift
About 8 months later, the jerky 3-4 shift returned, although not as bad as initially, and the 4-3 shift was fine. I did another transmission adaptation reset and it fixed it again for about 3 months. Then it came back, I did another reset and then it lasted about a month before it came back. Then I did another reset, it lasted about a week before it came back. Then I did another reset, and it lasted only about one day. I did it a few more times to make sure, and it only lasted a day. I saw that Porsche extended the transfer case warranty to 10 years, but unfortunately by now mine is just a little bit over 10 years old. So I decided to just live with it, since I could just manually shift it, or drive it hard and make sure to shift 3-4 over 2300RPM, and I almost never have anyone in the car with me anyway. (Mind you, this whole time, even when my shifts were smooth, the transfer case often shudders badly when making slow left turns, but not every single time. It's impossible to constantly reproduce it. Even a full lock left turn, sometimes it won't shudder.)
Last night, it just started shifting very hard and rough from 3-4. Like much rougher than a shift kit in an old school muscle car. No jerkiness, no slipping, just a hard rough shift. It did it when the car was cold too, which the jerky 3-4 shift almost never does. It occurs while manually shifting now too. I also tried to shift manually at 2500RPM and 3000RPM and it still had an equally rough shift. Didn't try any higher RPMs since I didn't have a safe chance to drive it that hard due to traffic. If I shift at super low RPMs like under 1500RPM, it shifts very smoothly.
The car has 138k now, so I didn't drive it much. Sorry don't have any further mileage info, like when the 3-4 jerky shift first came back.
Any ideas or suggestions? I'm in the Bay Area, CA, if anyone knows any shops that can properly diagnose it.
@Reltimestories: 958.1 and 958.2 have identical Aisin gearboxes.
thanks
thanks
