Anyone with Ohlins or Blistein EVO SE?
Old Apr 4, 2023 | 04:29 PM
Purekoryo's Avatar
Purekoryo
Default Anyone with Ohlins or Blistein EVO SE?
I currently have 992 S with SPASM with RAS and no PDCC.
What has your impression been with the Ohlins R&T or EVO SE? I know the latter can retain PASM adjustability but if Ohlins is noticeably better I’d rather get that.
This would be for just backroad semi aggressive driving and MAYBE some track time, so just looking for more fun / engagement. I also plan to max out the front camber and zero out the toes given stock components for some more feedback as well.
Also, how’s the installation process with these?
Old Apr 5, 2023 | 01:22 PM
Meraki Autoworks's Avatar
Meraki Autoworks
Basic Sponsor
The Bilstein EVO SE would be a good suite for what you're describing. If you were more track oriented I'd say maybe go the Ohlins route. But for more of a daily with spirited driving I'd say Bisltein.
We have them in stock as well.
-Josh
Your One Stop Aftemarket Shop!
Soul Performance / Akrapovic / Fabspeed / BC Forged / Bilstein / KW / CSF + more
Orange County, CA
Email: info@merakiautoworks.com
Text/Call: 213 394 2886
Website: www.MerakiAutoworks.com
Old Apr 9, 2023 | 01:27 AM
GTS2022's Avatar
GTS2022
-Josh
@Meraki Autoworks
I have a GTS. I’m perfectly fine with suspension, the way it drives, occasional track day , once or twice a year, all I want is to lower the stance a little bit without sacrificing ride. What’s the best choice for that? Thank you
Old Apr 10, 2023 | 01:22 PM
Meraki Autoworks
Basic Sponsor
Originally Posted by GTS2022
@Meraki Autoworks
KW Height adjustable springs will do the trick then, we have those in stock.
-Josh
Old Apr 10, 2023 | 02:00 PM
X-PH.COM - MIKE's Avatar
X-PH.COM - MIKE
Platinum Sponsor
I recommend the Bilstein
Old Apr 29, 2023 | 08:18 PM
Purekoryo's Avatar
Purekoryo
Does anyone have info on the spring rates for both? I’ve read a post about issues with blistein EVO SE being clunky. Might be just installation error, but just throwing it out there.
Again, anyone who has installed any of these coilovers, would appreciate your inputs.
Old Apr 29, 2023 | 08:19 PM
Purekoryo's Avatar
Purekoryo
Why? Other than adjustability of stock PASM system.
Old Apr 29, 2023 | 09:33 PM
peterjp's Avatar
peterjp
Default My Bilstein EVO SE Experience
I just purchased a 2022 Targa 4S and this time around spent the money on the Bilsteins. Ride in the normal mode is still firmer than stock, but comfortable. In sport mode I find the suspension handling is superior to the factory setup. I wish I had more places to drive where I could really take advantage of sport mode!
I like that fact that with the Bilsteins I still take full advantage of the Porsche PASM system.
Old Apr 29, 2023 | 11:16 PM
AlterZgo's Avatar
AlterZgo
I have Bilstein EVOs on my 992S. I think they improve both handling and ride quality and have found that the car rides better in all modes - normal, sport and sport+ with the Bilsteins. My car is modestly lowered. I think preserving more suspension travel always makes the ride better w/ coilovers.
Also, read thru this long thread for a lot of Bilstein EVO experiences:
https://rennlist.com/forums/992/1264...vaporware.html
Old Apr 30, 2023 | 01:40 AM
1957Goldtop's Avatar
1957Goldtop
@Meraki Autoworks
if you have a GTS the Billsteins aren't officially supported (although some here have them on their GTS)... I'vr emailed them multiple times to verify and they insist they aren't supported and have never been tested on a GTS.
Old Apr 30, 2023 | 03:04 AM
dixonk's Avatar
dixonk
Veteran: Army
How much did you lower it? I found it to be stiffer in every mode.
Old Apr 30, 2023 | 04:13 AM
AlterZgo's Avatar
AlterZgo
Mine is lowered 5/8" F and 1/2" R from stock SPASM. Did you have PASM or SPASM stock and do you have FAL? My car does not have FAL.
I think my stock SPASM suspension had noticeably worse ride quality than PASM cars I test drove and the Bilstein EVOs improved the ride quality over my stock SPASM suspension.
Also, with respect to FAL, the FAL version of Bilstein EVOs are not height adjustable in front and looks like it lowers a lot - like 1" lower up front vs. the 5/8" F lowering on my car.
Old Apr 30, 2023 | 04:49 AM
dixonk's Avatar
dixonk
Veteran: Army
I have PASM and dropped the car 20mm all around from stock ride height. It is noticeably stiffer in every drive mode.
Old Apr 30, 2023 | 05:18 AM
AlterZgo's Avatar
AlterZgo
That explains it. PASM rides noticeably better than SPASM. My stock SPASM 992 felt like a lowered car when completely stock, i.e. it felt like it lacked suspension travel and bottomed out and felt harsh riding. I was very pleasantly surprised that the Bilstein EVOs improved the ride quality. RK-D also felt this way when he installed the Bilstein EVOs on his Turbo S.
Do you have the FAL version of the Bilsteins?
Old Apr 30, 2023 | 05:40 AM
dixonk's Avatar
dixonk
Veteran: Army
No FAL for me. I used to switch the car to sport and sport plus mode every drive. After installing these I had to setup the individual mode to get the sport shifting with normal chassis for regular driving and when my wife is with me.
