Thinking about 5mm spacers. Do I need them?
Tim Schaefer (07-17-2024)
The following 3 users liked this post by P-daddy:
5mm is so little why bother? I do not generally like to do things on my car that alter the suspension geometry that the factory spent hundreds if not thousands of engineer hours developing.
Andy
Andy
The following 2 users liked this post by pp000830:
rlb993c2s (07-25-2024),
I have 5 all around in my 4S. Doesn't affect the bolt threading and fills the arches better. Could I have gone slightly bigger? Sure, a little but I didn't want too much spacer
im in exactly same frame of mind - I would like the oem wheels a little more pumped…they sit ‘in’
Can you go for 7mm all around with the oem bolts..anyone know if that works?
5mm is as much as I dare go. With Al lugnuts you want all the thread you can. And don’t forget the optimoly to get torque right. After running 18’s I had to put 5mm spacers on the front for 17’s as
the gap was just too “356” for my aesthetic.
The following 2 users liked this post by akrca4:
coreseller (10-29-2022),
I have a set of 4-5mm spacers, used them on the 996TTS wheels I was running before the Tramonts. I do not remember from where they came, maybe…maybe Fister.
I would be interested in passing them on…I’ll see if they have any manufacturer markings on them tomorrow.
Won’t be free, but will be cheap.
I’ll follow up tomorrow
@403portside - Get the spacers. You'll be pleased with the visual improvement.
Pay no attention to to the negative 'suspension geometry' waffle.
The following 4 users liked this post by Nurburger:
403portside (10-28-2022),
Full Boost (10-31-2022),
silverlock (10-29-2022),
Originally Posted by coreseller
Years back I messaged Opo regarding this very topic, I followed his advice of 7mm rears and 5mm fronts sourced from Ebay for my 96 NB. Ran them for years without issues.
