993 Forum 1995-1998
FS: aftermarket RS uprights - experience?
Old 10-04-2022, 11:04 PM
TheBen
TheBen's Avatar
Default FS: aftermarket RS uprights - experience?
In a quest to dial out a bit more bump steer, was thinking about rs uprights. Besides oem, both bbi and elephant manufacture them. Bbi is more $ but not by a wide wide margin.
Anybody on here have experience with either?
Old 10-04-2022, 11:52 PM
Achtung964
Achtung964's Avatar
I went with BBIs uprights. They are a work of art and supposedly have better geometry than the RS versions.
Old 10-05-2022, 12:05 AM
TheBen
TheBen's Avatar
Did you also procure the inner and outer tie rods to go with it?
Old 10-05-2022, 10:18 AM
Achtung964
Achtung964's Avatar
For tierods, I went with Tarrett Engineering.
Old 10-05-2022, 12:03 PM
Mr.Woolery
Mr.Woolery's Avatar
I also went with the BBi uprights. They're great.
Old 10-05-2022, 04:15 PM
Foxman
Foxman's Avatar
MCS 2 ways, BBI uprights, EVO tie rods, RS sway bars, and Elephant sport hardness bushings. The geometry that the BBI’s allow is incredible. See my refresh thread Here
Old 10-05-2022, 08:49 PM
TheBen
TheBen's Avatar
Thanks. Seems like BBi is the way to go.
Old 10-05-2022, 09:45 PM
cheez80
cheez80's Avatar
what a setup, thanks for sharing
Foxman (10-07-2022)
Old 10-05-2022, 11:34 PM
boomboomthump
boomboomthump's Avatar
Can't comment on the experience aspect, as my car is still in pieces but I decided to stick with factory...
My front setup:
KW V3's, RS uprights, GT2/Evo tie rods, RS drop links, RS swaybar, Elephant "sport" (RS style) bushings, Elephant camber plates.
Jarg1 (10-06-2022)
Old 10-26-2022, 12:18 PM
jeff33702
jeff33702's Avatar
For us 964 guys who go RS uprights... How do we order our dampers? Do we need 2 sets so we can put together fronts for a 993 and rears for a 964?
Old 10-26-2022, 07:11 PM
Achtung964
Achtung964's Avatar
My 964 KW V3s went on the BBI uprights no problem.
Old 10-27-2022, 12:10 AM
TheBen
TheBen's Avatar
Update: I purchased and received the bbi uprights. Now I have to pick my inner and outer rods and probably camber plates as I'm going down the that rabbit hole.
Old 10-27-2022, 01:03 AM
Foxman
Foxman's Avatar
TheBen, suggest you reach out to Steve Weiner and discuss the right suspension for you, and your driving. Steve takes a ground up approach, starting with tires. Steve helped me setup both my 993 and 964.
Old 10-27-2022, 01:24 PM
TheBen
TheBen's Avatar
Will do. Steve is great - bought some stuff from him years ago
Old 10-27-2022, 02:58 PM
71-3.0-911's Avatar
I think Steve retired unless he is doing consulting now...
Quick Reply: FS: aftermarket RS uprights - experience?
