AWC forged magnesium wheels, amazing unsprung weight saving for the money
Old 01-14-2021, 11:59 AM
J.Tan
J.Tan's Avatar
Default AWC forged magnesium wheels, amazing unsprung weight saving for the money
Disclaimer: I'm not paid or benefited in anyway by AWC to post this thread. I just want more people to know about this awesome company and their products.
AWC just post a story on their Instagram showcasing one of their forged magnesium wheels. I took a screenshot of it to show what the wheels look like. I can't link it since it's a story post.
The wheels seem to be in similar design as the Forgeline GS1R. The split 5 open lug design is considered to be one of the most optimized design in terms of strength to weight ratio. Here are the specs based on the audio in the post. Fronts are 19x9 and weigh 15.5lbs each. Rears are 19x10 and weigh "just under 16lbs" each. In my case, I have the heaviest 997 wheels the Carrera Sport. I will be able to achieve around 42.75 lbs of unsprung weight saving if I were to go with the same design but in 19x9 and 19x11 size. That's pretty insane. Also the starting price for a set of forged magnesium is around $5,800. I think that's pretty reasonable for a set of custom forged magnesium wheels.
They also showcased another set of forged magnesium wheels in the Ruf 5 spoke design. 19x8.5 18 lbs. 19x11 20 lbs. They are still pretty light but the weight is definitely compromised due to the chucky 5 spoke design.
Personally, I'd rather spend $6k for a set of wheels like these than wheels like BBS E88.
The following 3 users liked this post by J.Tan:
997ajk (01-15-2021), DesmoSD (01-15-2021), Robocop305 (02-09-2021)
Old 01-14-2021, 12:52 PM
andino
andino's Avatar
AWC has been pretty interesting. They can make anything you want pretty much as each wheel is a bespoke design tailored to your setup. They also do 3 piece wheels if that's the look you're after which is pretty cool. Their phone dial style wheels look pretty amazing.
Old 01-14-2021, 01:16 PM
arscottp
arscottp's Avatar
I like their 19" turbo twist wheels. Must resist.
The following 2 users liked this post by arscottp:
acr89 (01-14-2021), DesmoSD (01-15-2021)
Old 01-14-2021, 01:54 PM
arscottp
arscottp's Avatar
In terms of amazing weight saving/$. They are only slightly better than a set of Titan T-S5 wheels, although the potential to save more weight is larger.
https://titan-7.com/products/t-s5-fo...33593157222488
https://titan-7.com/pages/wheel-weight-chart
https://rennlist.com/forums/997-foru...l-weights.html
Old 01-14-2021, 02:03 PM
andino
andino's Avatar
24lbs of unsprung weight is pretty significant savings over the Titan7s. Prob not the most cost effective when compared to the Titan7 wheels but if the goal is to make as much savings as possible, it's a matter of grams and ounces.
Old 01-14-2021, 02:37 PM
J.Tan
J.Tan's Avatar
@arscottp & @andino , we definitely think alike! I'm a big fan of the Titan7 wheels too. They are by far the best bang for buck forged wheels. I was in fact one click away from buying a set of Titan7 T-S7 in iridium silver, but then I found out about the forged magnesium wheels that AWC makes. Typically the weight saving/$ ratio tanks badly once the wheels become really light. Like some of the high end BBS, Forgeline and HRE monoblock forged wheels. There are also carbon wheels like Carbon Revolution C9 wheels. Those typically range from $8k to more than $10k to achieve about the same or worse weight saving as the AWC mag wheels. So I consider the AWC mag wheels a bargain.
Old 01-14-2021, 03:29 PM
Sporty
Sporty's Avatar
Hmm , nice selection of wheels and choices. Any idea of HP/Trq to rotating weight ratio? For example , losing 30lbs of rotating weight is equivalent in feel to adding xxx HP / Trq ?? Aslo, how strong are these wheels for street use, potholes , etc. compared to a typical, OEM , heavier cast wheel I wonder?
Too bad Canadian $ has just gotten stronger against the US$; few a months ago would've been even more of a bargain if paying in US$.
Old 01-14-2021, 04:03 PM
J.Tan
J.Tan's Avatar
There are debates all over the internet about the conversion ratios. I don't want to trigger another one here. But I will show it for reference.
For me, 1lb of rotating weight equals to 6lbs of static weight. And every 9lbs of static weight removed equals to 1 hp. So saving 42.75 lbs of rotating weight is equivalent to gaining 28.5 hp. Again this is for refence ONLY. There's also the benefit of handling and braking improvement from much lighter wheels.
There's a comparison from Litespeed Racing, another great company that makes mag wheels but not as cheap as AWC. Forged magnesium is superior in both fatigue strength and tensile strength, yet it's less dense than 6061 T6 aluminum. 6061 T6 aluminum are the typical material used to make forged aluminum wheels. The typical order of strength in terms of wheel construction type is forged magnesium > forged aluminum > flowformed > low pressure cast > gravity cast. I'm only comparing monoblock vs monoblock. Most OEM style wheels are low pressure cast.
DesmoSD (01-15-2021), kru911 (01-14-2021), Snbrder (01-14-2021)
Old 01-14-2021, 06:02 PM
Sporty
Sporty's Avatar
Not a bad deal, improved looks, strength, handling and more effective "power increase" for the $. Thanks for the thorough response and good luck with the project.
Old 01-15-2021, 08:23 AM
Shock Arrival
Shock Arrival's Avatar
That's a good looking wheel and a lot of weight saved for your light-weight project! Looking forward to seeing what you choose...
Old 01-15-2021, 04:28 PM
997ajk
997ajk's Avatar
I used to think that Spoon wheels (magnesium - SW388) were light at 3.88 kg (9lbs) for 15x7" wheels , this is another level..
Great looking wheels and insanely light.
Old 01-17-2021, 04:24 PM
arscottp
arscottp's Avatar
Not sure what your lug bolt plans are, but Ti saves ~1.5 lbs for $240. 0.00625 lb/$. Similar range to the wheels.
https://www.acerracing.com/collectio...14347910152227
https://www.6speedonline.com/forums/...um-lugs-2.html
PCCB conversion would save maybe 30lbs coming from non S brakes. But thats big money.
Old 01-17-2021, 05:16 PM
J.Tan
J.Tan's Avatar
I have the MRG titanium stud conversion kit. Those are nice and saved 2 lbs of rotating mass.
https://www.vividracing.com/mrg-tita...151578748.html
PCCB conversion is nice but lb/$ wise. It's not great. Good thing is that the base Carrera has the smallest and lightest steel brake setup in the lineup. I won't need to upgrade them since I don't track and car. There's also a lot less mass for the brakes to stop with all the weight I'm removing too.
Old 01-17-2021, 05:59 PM
TheTorch
TheTorch's Avatar
For reference, I had a set of customer Signature Wheels made for my C4S to replace my Turbo wheels. They cost $3,600 all in including shipping: custom offsets, made to order door to door in 4-6 weeks, and the 19 x 11.5" rear wheel was under 20 lbs. The front wheel was 19 x 8.5" and around 16 lbs. Get some titanium lug bolts and you are saving at least 35 lbs of unsprung weight -- more if you were using spacers.
Old 10-12-2022, 11:55 AM
Snowy999
Snowy999's Avatar
Just found this. These are my 19" wheels for a GT4. Excellent except just too tight for the 991 GT3 front calipers. Swapped to 997.2 GT3Rs calipers, no change to discs and wonderful fit and massive weight saving!
J.Tan (10-14-2022)
Quick Reply: AWC forged magnesium wheels, amazing unsprung weight saving for the money
